Getting all Girlie
General discussion about Scoobs.
Getting all Girlie
Postby idf101 » Thu Sep 30, 2004 3:25 pm
:D Just had the call from my dealer new one will be ready tommorow pm, so i am getting all excited but trying not to show it to er indoors!
Just booked next week off to try and run in over next days 8 or so.
Anything in particular i should be aware of?
idf101
Postby jaycee » Thu Sep 30, 2004 3:30 pm
Jealousy from normal scooby owners!!!
Jason
jaycee
Postby Gangsta Smurf » Thu Sep 30, 2004 3:37 pm
roundabouts ... :wink: :wink: :wink: :wink: :wink:
I ran mine in within 48 hours ... can you beat it!
Gangsta Smurf
Postby Cold Turkey » Thu Sep 30, 2004 3:52 pm
do it by the book for the first few hundred miles - say 500 - but don't sit at 4000rpm, vary the gear changes and rpm
after that don't be afraid to blip into the bigger revs - upto 6000rpm for instance when overtaking - just don't sit too high for too long
most of all, ENJOY 8)
Cold Turkey
Postby chris » Thu Sep 30, 2004 4:05 pm
If you're on the motorway make sure that you don't sit at the same revs all the time.
And don't forget to put a sign in the rear window that says "running in please pass" :wink:
chris
Postby Brian » Thu Sep 30, 2004 5:10 pm
as like every 1 says...
I run mine in for about 600 miles and then took the revs up ... slowly.. till i reached 1000 miles
its all about not loading the engine too much, a few high revs is fine but dont load it too much
and Towing is out of the question ;)
Brian
Postby Sumo » Thu Sep 30, 2004 5:34 pm
Before someone above mentions it, you have to make sure you don't drive like a fairy, this teaches the ECU a false picture of engine limits, so if you then come to give it some stick it will say 'no chance' and back off the timing etc, how do I know this, this is exactly what mine did at the rolling road meet, fortunatly Mike Wood was there from Prodrive so he reset the ECU and told me that I needed to use all of the rev range (he could see what revs I had used from new). So give it a bit of a rev every now and again. As far as I know the car that gave the most power on the day had been hammered the most during its running in period (flat chat down the mulsanne straight). dont know if thats any help
....................................Sumo :twisted:
Sumo
Postby Brian » Thu Sep 30, 2004 5:45 pm
Sumo wrote:Before someone above mentions it, you have to make sure you don't drive like a fairy,
No comment !!
Like Sumo says, treat it hard and it will produce what you want.. ;)
Brian
Postby jimhutch » Thu Sep 30, 2004 6:50 pm
lockjaw-----------------from smiling :D :D :D :D :D :D :D :D :D
fancy laying out milton keynes wiith this car in mind
jimhutch
Return to General Scooby Chat
