Fuel Consumption
Fuel Consumption
Postby seanyb » Thu Sep 15, 2011 11:20 pm
Hi I drive just over a hundred miles each way to work, I get there on a quarter tank so I'm getting about 400 miles to a tank this is mostly at 70 to 80 on dual carriageways I run Shell V power is this unusual as I have been told by a lot of people they only get about 250 miles to a tank?!!
seanyb
Postby Steveyk » Fri Sep 16, 2011 4:37 am
have you you actually got the engine turned on? 400 miles is impossible. I couldn't get 400 miles out of mine if I was pushing it :lol:
Steveyk
Postby Matty WR1 » Fri Sep 16, 2011 7:14 am
LOL! best I've ever seen was 260 miles on a tank....
I average 200 miles a tank, the same in my WRX :D
Matty WR1
Re: Fuel Consumption
Postby eck » Fri Sep 16, 2011 8:17 am
seanyb wrote:Hi I drive just over a hundred miles each way to work, I get there on a quarter tank so I'm getting about 400 miles to a tank this is mostly at 70 to 80 on dual carriageways I run Shell V power is this unusual as I have been told by a lot of people they only get about 250 miles to a tank?!!
Is it an imaginary WR1
eck
Postby Matty WR1 » Fri Sep 16, 2011 8:24 am
could be one of those small turbo ones ;)
Matty WR1
Postby Azyman » Fri Sep 16, 2011 8:58 am
My partner got 260ish once I get an average off 170 so 400 is that on a trailer
:D
Regs
Geoff
Azyman
Postby seanyb » Fri Sep 16, 2011 12:21 pm
Lol i know you think i'm nuts but it's 210 miles give or take for me to go to work and back and i can do it on half a tank at motorway speeds, car has been on the rollers is putting out 315bhp 1.5 bar boost original map.
seanyb
Postby eck » Fri Sep 16, 2011 1:51 pm
Think you must have a 100 litre fuel tank
How many miles do you do between fuel stops?
eck
Postby Megaman » Fri Sep 16, 2011 2:07 pm
350-400miles per tank are WRX figures and not STI mpg figures. You most certainly have got an issue and going by your figures it seems to be your turbo has been taken from a WRX not the genuine WR1 turbo.
Suggest you meet up with another WR1 owner and go for a blast in theirs and see if you think theirs feels any faster. But 400 on a tank of fuel is not doable given the WR1 std turbo is on boost at 70-80mph.
Alternatively you may have had a sedate open source remap put on limiting boost but still its not "normal".
Postby John Mc » Fri Sep 16, 2011 2:35 pm
Megaman wrote:.... it seems to be your turbo has been taken from a WRX not the genuine WR1 turbo.
Even when I had my WRX turbo in the WR1 I was still only getting 260!! :lol:
Postby Megaman » Fri Sep 16, 2011 2:45 pm
Surprising, my mates wrx got 300-350 a tank on motorway driving. Think you had a fuel leak amongst other things with your Redline Special :)
Postby huzzy » Fri Sep 16, 2011 3:08 pm
Well I filled mine up the other day after my usual 2 weeks of motorway miles.
55.65 litres to fill up at a cost of £80.08 and that gave me 334 miles which is 27.38 MPG.
I'd say that I'd probably done 200 miles to where the needle fell to half a tank but in essence the you wouldn't do 200 on the final 1/2 a tank.
As it stands now- 202 miles to just under half:
Previously:
Subaru Impreza WRX (P95 CJH)
Subaru Impreza WRX (DV52 LJZ)
Subaru Impreza WRX STI WR1#131(VE04 LUW)
Subaru Impreza STI Hawkeye Spec C (YD06 NGT)
Subaru Impreza 22B #377 (S22BHU)
Now:
Subaru Impreza STI Hawkeye Spec C Type RA
huzzy
Postby eck » Fri Sep 16, 2011 3:28 pm
huzzy wrote:Well I filled mine up the other day after my usual 2 weeks of motorway miles.
That's pretty good going, my Mrs just managed similar figures in her WRX
And please clean your dash thanks
eck
Postby CAVEMAN » Fri Sep 16, 2011 4:12 pm
thank your lucky stars you get that much, if you get the 200-250 like the rest of us that would certainly hurt your wallet...
Postby grahampesking » Fri Sep 16, 2011 5:47 pm
400 miles to a full tank :suss:
If I get 200+ I think Im lucky , :roll:
grahampesking
Postby Chris 280 » Fri Sep 16, 2011 8:10 pm
100 miles to and from work :shock: you must love work or driving thewr1 :lol: 400miles per tank :shock: the wr1 must be eco friendly after all :lol:
Chris 280
Postby Crockel » Fri Sep 16, 2011 9:49 pm
As most people have already said somethings wrong!
I drive like Miss Daisy a lot of the time so my mates reckon. I use the car daily and have had the same set of tyres on the car for the last 2 and a half years now ( :cry: ) and there's still around 3mm of tread on them! But the best I have ever managed is 290 miles on a full tank.
When you lift up the bonnet on your car do you see something like this?
Crockel
Postby seanyb » Fri Sep 16, 2011 11:12 pm
lol think I will need to fill her up and run her dry and see what I get, I 'm just assuming i'm getting that milage based on doing a hundred mile per quarter tank
seanyb
Postby seanyb » Fri Sep 16, 2011 11:17 pm
seanyb
Postby seanyb » Fri Sep 16, 2011 11:18 pm
seanyb
Postby grahampesking » Sat Sep 17, 2011 1:44 am
you can say that again :lol:
grahampesking
Postby Matty WR1 » Sat Sep 17, 2011 4:49 am
seanyb wrote:lol think I will need to fill her up and run her dry and see what I get, I 'm just assuming i'm getting that milage based on doing a hundred mile per quarter tank
LOL! So it's complete balls ;)
Matty WR1
Postby Megaman » Sat Sep 17, 2011 10:32 am
Hmm I fill mine with VPower and normally spend 50-60 for a full tank. Huzzy is filling up and spending 80 quid. I wonder if either our fuel gauges are out or if some wr1's have different size fuel tanks. Never really looked at the number of litres I put in just normally look at the bill... I know my low fuel light doesnt come on even when my fuel is below the bottom white line... hmm plot thickens. Who is going to be the first to try and run theirs completely out of fuel to see if the gauges are out? :lol:
Postby WR1 Bro » Sat Sep 17, 2011 10:44 am
60 litre tank iirc
Postby Crockel » Sat Sep 17, 2011 11:08 am
WR1 Bro wrote:60 litre tank iirc
On a 60 litre tank seanyb is getting just over 30 to the gallon then. If that is correct that it up there with a man running the 4 minute mile and Neil Armstrong setting foot on the moon :lol:
L
Crockel
Postby Chris 280 » Sat Sep 17, 2011 7:33 pm
had the warning light on and dont think id get more than 20 miles on it b 4 totlly mt
Chris 280
Postby chiroman » Sun Sep 18, 2011 4:35 pm
I was doing motorway miles a few yrs ago and had been in touch with Bob Rawle re mpg.
I took his advice and drove off boost ie 65mph ish for a wk and managed 29mpg average. Tesco 99 refilled as always at a quarter full takes about 40litres.
After a week of this misery in the slow lane of the M25 normal service was resumed in the fast lane and 23mph irc.
The Wr1 fuel gauge definitely not linear and hardly moves from full for a couple of gallons. Then its connected directly to the accelerator pedal.
Also for a year I was doing a local twisty B route and did about 16mpg which was a real shock as I had been doing the same route in Vectra 2.6SRi and 25mpg. Dare I say I do miss the bottom end torques of the Vectra.
As an aside, while Vectra being serviced, I borrowed a 1.6 Astra from the Vauxhall dealer and thrashed it unmercifully in an attempt to drive at same speeds, achieving a magnificent 25mpg on its computer.
I did also make enquiries with Mocom racing, when they were in North Weald, to see whether economy maps were feasible. But the answer was a negative as likely to blow the engine first time I booted it.
400 mile to a tankful, I couldn't get that on the back of a breakdown truck.
chiroman
Postby MaverickUK82 » Mon Sep 19, 2011 3:39 pm
Megaman wrote:Hmm I fill mine with VPower and normally spend 50-60 for a full tank. Huzzy is filling up and spending 80 quid. I wonder if either our fuel gauges are out or if some wr1's have different size fuel tanks. Never really looked at the number of litres I put in just normally look at the bill... I know my low fuel light doesnt come on even when my fuel is below the bottom white line... hmm plot thickens. Who is going to be the first to try and run theirs completely out of fuel to see if the gauges are out? :lol:
It's about £80 to fill mine from empty - VPower.
Postby seanyb » Thu Sep 22, 2011 2:25 pm
For me to fill up from quarter tank is about £60 that's vpower at £1.39 this time I reset the trip meter drove off boost hit the three quarter tank mark at 97 mile hit the half tank at 187 miles then I had to thrash it cause I was late for work! Lol science is hard :)
seanyb
Postby WR1 Bro » Thu Sep 22, 2011 2:27 pm
seanyb wrote:For me to fill up from quarter tank is about £60 that's vpower at £1.39 this time I reset the trip meter drove off boost hit the three quarter tank mark at 97 mile hit the half tank at 187 miles then I had to thrash it cause I was late for work! Lol science is hard :)
LOL at "science is hard"... but it sounds like fun!
Next
Users browsing this forum: No registered users and 9 guests
