Performance Creations Mudflaps.
Postby huzzy » Fri Jan 15, 2010 4:31 pm
I've just tried fitting a set to my car. Has anybody else successfully fitted a set?
I'm having trouble self tapping the final screw to the chassis, tried drilling it. Took the wheel off to try and drill without doing it so awkwardly and still couldn't get the screw in.
Anybody with any advice?
Previously:
Subaru Impreza WRX (P95 CJH)
Subaru Impreza WRX (DV52 LJZ)
Subaru Impreza WRX STI WR1#131(VE04 LUW)
Subaru Impreza STI Hawkeye Spec C (YD06 NGT)
Subaru Impreza 22B #377 (S22BHU)
Now:
Subaru Impreza STI Hawkeye Spec C Type RA
huzzy
Postby huzzy » Fri Jan 15, 2010 7:23 pm
Heres an idea, I'll use a High Speed Steel drill bit to drill it instead of using a wood drill bit!
The wonders of Google.
Previously:
Now:
huzzy
Postby Bonovox » Fri Jan 15, 2010 7:51 pm
huzzy wrote:Heres an idea, I'll use a High Speed Steel drill bit to drill it instead of using a wood drill bit!
:lol2:
remember not to fasten them on with nails :wink:
Bonovox
Postby eck » Fri Jan 15, 2010 9:04 pm
:lol2:
Should have just used Surerglue, no drilling required :D
eck
Postby huzzy » Sat Jan 16, 2010 10:46 am
Now fitted after acquiring the correct drill piece and I must say they look the dogs.
Highly recommended.
Previously:
Now:
huzzy
Postby Azyman » Sat Jan 16, 2010 10:51 am
:D D I Y SoS
Regs
Geoff
Azyman
Postby huzzy » Sun Jan 17, 2010 3:47 pm
And here they are:
Previously:
Now:
huzzy
Postby Foley » Sun Jan 17, 2010 6:37 pm
They look good but i think they stick out to much at the sides, imo
Postby John Mc » Sun Jan 17, 2010 9:03 pm
Foley wrote:They look good but i think they stick out to much at the sides, imo
I've got the same ones, I don't think mine stick out that much... I can't remember if there was a front and rear set or whether they were the same?!
Postby Clark » Sun Jan 17, 2010 9:35 pm
look fine to me. After all, you want them to stick out a bit otherwise they wont do their job very well... 8)
