Time Attack 2008 STi - new dyno figures !!
Post pictures of your car and tell us the spec. It doesn't have to be a WR1!
Postby WR1 Bro » Sun Jul 06, 2008 8:42 pm
OMG
Postby Chris B » Sun Jul 06, 2008 8:58 pm
Some good pics of duncs car on SIDC see general disscusion and look for time atttack.
Chris B
Postby WR 1mposter » Sun Jul 06, 2008 11:53 pm
It could have been worse dunc.
Head on and all the aps fmic would be wasted.
and more important you got out to laugh at it !
Postby dynamix » Mon Jul 07, 2008 6:51 am
Head on and there would have been a huuuuge bill. I did take out insurance so the most it would have cost me was the excess though but it still would have hurt and I certainly wouldnt have been able to drive it home.
Amazed :o
Duncan : www.racedynamix.com
email: duncan@racedynamix.com
tel: 07540 185754
dynamix
Postby danr55 » Mon Jul 07, 2008 7:35 am
ouch.
big excess? Could have been a lot worse. If you;re going to do regular trackdays/racing you have to expect that once in a while something like this will happen I guess.
Don;t worry Mac-1 got his outing into the armco over and done with ages ago :wink:
Postby jd » Tue Jul 08, 2008 7:12 am
:shock: glad you are ok.
1mposter is my hero.
jd
Postby dynamix » Thu Jul 10, 2008 9:52 am
danr55 wrote:big excess? Could have been a lot worse. If you;re going to do regular trackdays/racing you have to expect that once in a while something like this will happen I guess
excess is bigger than the damage really.
The aftermath:
Closer investigation of the damage from the accident have revealed how lucky I was. The silver scuffs that you see on the paintwork arent my paint, they are the paint from the barriers on top of mine so will clay bar out leaving remarkably few actual dents and scratches.
The front wing does need replacing but I was gobsmacked to find out that they are £71.08+vat from the main subaru dealer - BARGAIN !!
The only other two bodywork parts are the wheel arch protector and a side repeater which are £100 for the pair.
With a bit of gentle hammering the rest should be fine :D
The alloy wishbone, ball joint and track rod end took the full force of the impact but it looks like the damage stopped there as there is no damage to the actual mounting points, chassis rails or steering rack. These Subarus are very well built despite what some on here would say ;)
The brake disc on that side is history so it is a good time to upgrade to a more motorsport package. I did look at KSports but decided against them in favour of StopTech's based on others experience. Will still run these with Performance Friction pads as they have hugely impressed me over a long period of time. I may go for the .97 compound pads this time which are the compromise between the Z rated road/track version and the .01 compound full race version.
New wheels are on their way shortly to replace the damaged pair and it will be back on track soon and 100% ready (apart from some battle wounds) and tested for the Ring Trip in August
tel: 07540 185754
dynamix
Postby danr55 » Thu Jul 10, 2008 11:10 am
The aftermath:
£71 for a whole wing, and £100 for wheel arch protector and side repeater?! :rofl: :loony:
Good news that the plans for repairs are all under way :D
Postby WR 1mposter » Thu Jul 10, 2008 8:58 pm
Ring trip in august dunc ? ......
Postby POESY » Fri Jul 11, 2008 1:27 pm
:oops!:
Anyway, live to fight another day. After all, these things happen fella - to all of us!!
POESY
Postby dynamix » Fri Jul 11, 2008 9:29 pm
WR 1mpostor (aka number 1 moderator) wrote:Ring trip in august dunc ? ......
yep - going over for a week with my wife and daughter for a family holiday sightseeing, drinking by the campfire and driving round the track - should be fun :D
tel: 07540 185754
dynamix
Postby dynamix » Wed Jul 23, 2008 6:00 pm
I've had a change of mind on the brakes, instead of changing to Stoptech's I have decided to stick with Performance Friction discs on the standard brembo calipers. I have always been very very happy with these so decided against spending extra money on an upgrade as tempting as it was to do.
So... these, along the other parts will be put on by me on Friday and it will be back to close to it's original state then.
Also got a couple of ABS sensors from Grade A for £40 each (better than £165 each from the dealer) to see if that fixes the ABS warnings.
Friday is going to be a hard day and test my mechanical abilities. The jobs are:
1. replace lower wishbone
2. replace ball joint for Whiteline RC adjusted version
3. replace track rod end for Whiteline version
4. replace both front discs
5. raise the car by 5mm to cope with the nurburgring's undulations and kerbs
6. re-do geometry
7. replace oil cooler core
8. check all pipework
Should be fun
anyway cracked on with a few things today and all warning lights are now gone :D :woohoo:
ABS sensors have been replaced with the £40 jobs from Grade A. These arrived next day and were a doddle to do so cracked on with them tonight - only took 20 mins to do the pair of them.
Also put my little 3 ohmn resistor into the airbar connector under the seat so now I have fully functioning ABS and Airbags.
Ride height has been upped too, so that should make it easier to trailer over to germany and should help with the ground clearance issues in the Karussel and other places where the kerbs are ridden extensively. It has had an effect on the geometry but that was all shot to pieces anyway to be honest :lol:
Next to do the suspension parts and brake discs on friday and it is all set.
tel: 07540 185754
dynamix
Postby dynamix » Fri Jul 25, 2008 9:59 pm
wow - back from Northampton. Paul at Zen kindly offered me use of a ramp today so that I could do the bits while I was picking up the discs and whiteline jobbies. I got everything done
so today have done:
1. replace lower wishbone (the old one was scrap)
2. replace ball joint for Whiteline RC adjusted version (i have a spare too now)
3. replace track rod end for Whiteline version (also got a spare)
4. replace both front discs (how many bolts hold these fekkers on !!)
5. re-do geometry ... it was a looooooooooooooong way out :D
6. replace oil cooler core with a newer bigger core as the old on ewas split
7. check all pipework
8. replace gearbox mount with group N mount as the old one was bent by about an inch with the impact. Could not believe the damage on this, it must have taken a bit of a bash.
Got an amazing amount done, and am so thankful to Paul for this.
The trip home was awesome having to bed the brakes in according to Performance Frictions instructions... god love em :D
Nice to get home excited again B)
Sorry no pictures :(
tel: 07540 185754
dynamix
Postby WR 1mposter » Sun Jul 27, 2008 9:51 am
When are you going Dunc ?
Postby dynamix » Mon Jul 28, 2008 7:04 am
16th August for a week :thumb:
tel: 07540 185754
dynamix
Postby WR 1mposter » Mon Jul 28, 2008 10:26 pm
dynamix wrote:16th August for a week :thumb:
I'll be at Trier watching the german wrc, we'll be at the ring at somepoint between 13/18th august...may see you there !
Postby dynamix » Tue Jul 29, 2008 11:34 am
Cool :D
tel: 07540 185754
dynamix
Postby WR1 Bro » Tue Jul 29, 2008 12:08 pm
dynamix wrote:Cool :D
Hi Dunk. The word "cool" can never be used in connection with Pasty.
Postby WR 1mposter » Tue Jul 29, 2008 10:24 pm
stfu nasty daddy took away the boys toys :roll: :roll:
Postby dynamix » Tue Aug 12, 2008 7:23 am
Just back from Brands after doing testing day ....
The car survived around 140 laps of BH without too many issues so it should cope with 12.7 miles at a go next week :D
some pics:
a certain Mr Phil Glew giving it hell around the track - loved watching this in between biting all my nails off when he braked around 150 metres later than I thought I would into paddock :o
tel: 07540 185754
dynamix
Postby WR1 Bro » Tue Aug 12, 2008 7:25 am
Looking good Dunc...
Postby dynamix » Tue Aug 12, 2008 7:33 am
thanks Bro - I was dead chuffed I managed to get that shot.
Got some great feedback from Phil on the car's handling and set up that should help for plans for the next developments. Very useful and informative day.
tel: 07540 185754
dynamix
Postby WR1 Bro » Tue Aug 12, 2008 8:27 am
How do you ever get any paying working done?
What suspension are you on?
Postby dynamix » Tue Aug 12, 2008 8:30 am
WR1 Bro wrote:How do you ever get any paying working done?
yeah lots - need to do more and more to pay for this season :o
WR1 Bro wrote:What suspension are you on?
Exe-tc - love it :)
tel: 07540 185754
dynamix
Postby WR1 Bro » Tue Aug 12, 2008 8:33 am
Exe-tc - love it :)
Who fitted yours and how much did it cost you?
Postby dynamix » Tue Aug 12, 2008 8:40 am
ASP supplied them - Mocom fitted them
Zen do the whole package on them if you want supply and fit / alignment in one go - I am sure they will sort you out on the best price on them but they are not cheap.
tel: 07540 185754
dynamix
Postby WR1 Bro » Tue Aug 12, 2008 8:44 am
dynamix wrote:ASP supplied them - Mocom fitted them
I know they are not cheap.
I'll get a price from Zen and from RCM and see which is best. Sssshhhh, don't tell the wife!
Have you got any pictures of the inner wing filter you use?
Postby danr55 » Tue Aug 12, 2008 12:22 pm
Great pics Dunc.
I'd love to get a better suspension set up, quite like the prodrive setup but evertime I look at trackday pics I see how much the car is leaning!
Postby WR1 Bro » Tue Aug 12, 2008 12:28 pm
danr55 wrote:I look at trackday pics I see how much the car is leaning!
Have you considered a DIET?
Postby danr55 » Tue Aug 12, 2008 2:30 pm
maybe my passenger needs a diet looking at the pics? :lol: :lol:
PreviousNext
Return to The Garage
