Azymans project
Postby Azyman » Tue Oct 14, 2008 12:27 pm
danr55 wrote:What else are you doing with the car? TMIC is absolutely fine to at least 360 BHP
hi Dan
i have been told that it is ok to run 450-500 Bhp as i am getting my car quoted as we speak, i had read the above and have been assured it will be fine but still am thinking of the FMIC thou but i need a lottery win to get all the rest done :shock:
the list is endless thou as for all the other items thrown in :D
i am going the route of forged internals to help with the foundation as dynamix has mentioned
Regs
Azyman
Postby danr55 » Tue Oct 14, 2008 1:55 pm
hi Dan
Hi Geoff,
Seems you are getting carried away with the spec now, that's what we like to see, top man :thumb:
Have you decided who is doing the build?
Dan
Postby Azyman » Tue Oct 14, 2008 2:52 pm
danr55 wrote:
hi Dan
Hi Geoff,
Dan
i have decided to go with RCM
hoping for between 450-500 when finished not cheap thou
but have decided to keep the car so in theory it is like trading it in and getting new car [well thats what ive told the g/f]
will post a list up of all the parts! must say top people at RCM amount of questions i have asked and had answered
:D
Regs
Azyman
Postby danr55 » Tue Oct 14, 2008 2:59 pm
Azyman wrote:
danr55 wrote:
hi Dan
Hi Geoff,
Dan
:D
Result. You won't be disappointed with the results. Which turbo are you going for? GT35 P20?
Postby Megaman » Tue Oct 14, 2008 3:45 pm
danr55 wrote:Result. You won't be disappointed with the results. Which turbo are you going for? GT35 P20?
Only one turbo?? :)
Has anyone looked into twin turboing a scooby? :)
Postby marky mark » Tue Oct 14, 2008 3:50 pm
Only one turbo?? :)
Yep, Subaru have, it's called a legacy.
Postby Azyman » Tue Oct 14, 2008 7:06 pm
HYBRID GARRETT RCM450 GDA/B
GT35/VF HYBRID TURBO FITTING
800CC UPRATED INJECTOR KIT G
RCM 3'' COMPLETE SYSTEM GC8
3'' EXHAUST SYSTEM FITTING K
RCM STAINLESS MANIFOLD & UP
RCM MANIFOLD FITTING KIT
SAMCO BLUE INDUCTION BYPASS
SAMCO AIR BOX HOSE 78MM-73MM
STAINLESS STEEL HOSE CLAMP 7
SPARK PLUG NGK IRIDIUM FOR U
RCM INDUCTION KIT GDB NEW AG
MAPPING SESSION
PISTON RING SET EJ207/8 STD
HONE CYLINDER TO PISTON X4
OMEGA PISTON STD SIZE V7/8 G
RCM H SECTION UPRATED CON RO
ACL RACE REAR THRUST MAIN BE
ACL RACE BIG END BEARING SET
14MM/14MM WRC HEAD STUD KIT
HEAD DRILLING FOR 14MM STUDS
HEAD DOWEL FOR 14MM STUD KIT
RCM HEADGASKET MODIFICATION
HEAD GRIND
MODIFIED OIL PUMP
ENGINE GASKET SET EJ205 11/0
SILKOLENE PRO R 5 LTR 15W50
GENUINE SUMP WASHER
OIL FILTER SF5 + GGB 11/02+
BLOCK FACE SKIM GC8
this is most of the parts so far
and a lottery win :D
Regs
Azyman
Postby wr1.305 » Tue Oct 14, 2008 7:20 pm
sounds great but means nothing to me haha, how fast dose the noise peddle make you go??? lol
MODIFIED OIL PUMP ??? how?
wr1.305
Postby Azyman » Tue Oct 14, 2008 8:59 pm
wr1.305 wrote:sounds great but means nothing to me haha, how fast dose the noise peddle make you go??? lol
haha dont mean a lot to me either but sounds good!!!
Regs
Azyman
Postby danr55 » Tue Oct 14, 2008 9:52 pm
that's not far off a Chris/RosyB spec. 8)
DO IT!
Postby danr55 » Wed Oct 15, 2008 7:35 am
Geoff, what ECU is being planned with that spec?
Postby Azyman » Wed Oct 15, 2008 11:08 am
danr55 wrote:Geoff, what ECU is being planned with that spec?
no Mention of any ECU will it need upgrade 1 then?
Regs
Azyman
Postby danr55 » Wed Oct 15, 2008 11:14 am
Worth asking the question, not sure if the WR1 standard ECU is up to that... :? I think they're good to about 400ish BHP, but not too sure....
Postby Azyman » Wed Oct 15, 2008 12:43 pm
nope its ok if i want to go any further then 450-500 then it will need to be changed result!!
Regs
Azyman
Postby Megaman » Wed Oct 15, 2008 12:56 pm
danr55 wrote:Worth asking the question, not sure if the WR1 standard ECU is up to that... :? I think they're good to about 400ish BHP, but not too sure....
This may be a daft question but why do you need to change the ECU when you get more power??? Surely the ECU is still doing the same job of timings and fuel ratios etc... ?!
Postby danr55 » Wed Oct 15, 2008 5:34 pm
it's to do with boost I believe. Standard ECU can't cope with the sort of boost you'll run with that kind of power and a larger turbo. Someone more technical will give you more info. The ECU on the newer cars is better though, thankfully! :lol:
Postby JP » Wed Oct 15, 2008 8:02 pm
Mega - also that you can get fancy bits like Launch Control and Anti Lag.
JP
Postby Azyman » Fri Oct 17, 2008 2:52 pm
Well The Cars Booked in with RCM
the start date is March 2009 plenty of time to save some cash
going for 450-500 BHP
must say Tim From RCM top bloke!
all the questions ive asked he has answered with ideas and sugestions to help save a bit here and there,i feel fully confident in it all
but now its a waiting game
at least its crap weather so not to bad
Regs
Azyman
Postby WR1 Bro » Fri Oct 17, 2008 2:55 pm
Happy days... Very please for you. I'm sure you will be over the moon.
Postby danr55 » Fri Oct 17, 2008 3:18 pm
Excellent stuff. What was the end result on the ECU?
Postby WR1 WOZA » Fri Oct 17, 2008 4:45 pm
Great news Geoff :lol:
You can tell me all about it when i see u next :!: :woohoo:
Good luck with the lottery win or start the saving :thumb:
How much is the build :?: Maybe discount for a group buy :roll:
WR1 WOZA
Postby Azyman » Fri Oct 17, 2008 5:45 pm
danr55 wrote:Excellent stuff. What was the end result on the ECU?
the one in it is ok :D
unless i want to go over 500 bhp lol :lol: maybe when the kids buy it of me they will
Regs
Azyman
Postby danr55 » Fri Oct 17, 2008 9:07 pm
wr1 standard ECU up to nearly 500 BHP? Hmmmmmm....... :?
Postby Azyman » Wed Oct 22, 2008 11:31 am
got my new turbo today they recon it should be good for 600 BHP
let me know if you think it is ok ?
Regs
Azyman
Postby rocko » Wed Oct 22, 2008 3:52 pm
Think it would be Best if you got it ceramic coated first .. should push 650 then .... :D
rocko
Postby WR 1mposter » Wed Oct 22, 2008 9:42 pm
He is correct Dan :wink:
Result Geoff, you won't find anyone better than RCM .....Young Tim is a sound bloke aswel :wink:
Postby danr55 » Thu Oct 23, 2008 7:56 am
Fair play! I didnt realise they could cope with that power/boost but I'm sure they know what they're doing! 8)
Postby WR 1mposter » Fri Oct 24, 2008 9:38 am
As do all tuners :roll: :lol: :lol:
Postby marky mark » Fri Oct 24, 2008 10:50 am
Tim came round my gaff last night to pick up a few bits, i mentioned to him that someone i knew has been saying nice things about him on the internet and he was very interested to know what and who!
Postby Azyman » Sat Oct 24, 2009 7:13 am
YeeeeHaaaaaaa the car geos in today at long last!!!!
:D
Regs
Azyman
Next
