by Azyman » Tue Oct 14, 2008 12:27 pm
danr55 wrote:What else are you doing with the car? TMIC is absolutely fine to at least 360 BHP
hi Dan
i have been told that it is ok to run 450-500 Bhp as i am getting my car quoted as we speak, i had read the above and have been assured it will be fine but still am thinking of the FMIC thou but i need a lottery win to get all the rest done
the list is endless thou as for all the other items thrown in
i am going the route of forged internals to help with the foundation as dynamix has mentioned
Geoff
Regs
Geoff
Azyman
by danr55 » Tue Oct 14, 2008 1:55 pm
Azyman wrote:danr55 wrote:What else are you doing with the car? TMIC is absolutely fine to at least 360 BHP
hi Dan i have been told that it is ok to run 450-500 Bhp as i am getting my car quoted as we speak, i had read the above and have been assured it will be fine but still am thinking of the FMIC thou but i need a lottery win to get all the rest done the list is endless thou as for all the other items thrown in i am going the route of forged internals to help with the foundation as dynamix has mentioned Cheers Geoff
Hi Geoff,
Seems you are getting carried away with the spec now, that's what we like to see, top man
Have you decided who is doing the build?
Dan
- Site Owner
by Azyman » Tue Oct 14, 2008 2:52 pm
danr55 wrote:Azyman wrote:danr55 wrote:What else are you doing with the car? TMIC is absolutely fine to at least 360 BHP
Hi Geoff, Seems you are getting carried away with the spec now, that's what we like to see, top man Have you decided who is doing the build? Dan
i have decided to go with RCM
hoping for between 450-500 when finished not cheap thou
but have decided to keep the car so in theory it is like trading it in and getting new car [well thats what ive told the g/f]
will post a list up of all the parts! must say top people at RCM amount of questions i have asked and had answered
Regs
Geoff
Azyman
by danr55 » Tue Oct 14, 2008 2:59 pm
Azyman wrote:danr55 wrote:Azyman wrote:danr55 wrote:What else are you doing with the car? TMIC is absolutely fine to at least 360 BHP
i have decided to go with RCM hoping for between 450-500 when finished not cheap thou but have decided to keep the car so in theory it is like trading it in and getting new car [well thats what ive told the g/f] will post a list up of all the parts! must say top people at RCM amount of questions i have asked and had answered
Result. You won't be disappointed with the results. Which turbo are you going for? GT35 P20?
- Site Owner
by Megaman » Tue Oct 14, 2008 3:45 pm
danr55 wrote:Result. You won't be disappointed with the results. Which turbo are you going for? GT35 P20?
Only one turbo??
Has anyone looked into twin turboing a scooby?
- Fords Number 1 Fan
by marky mark » Tue Oct 14, 2008 3:50 pm
Megaman wrote:danr55 wrote:Result. You won't be disappointed with the results. Which turbo are you going for? GT35 P20?
Only one turbo?? Has anyone looked into twin turboing a scooby?
Yep, Subaru have, it's called a legacy.
- JPs little helper
by Azyman » Tue Oct 14, 2008 7:06 pm
HYBRID GARRETT RCM450 GDA/B
GT35/VF HYBRID TURBO FITTING
800CC UPRATED INJECTOR KIT G
RCM 3'' COMPLETE SYSTEM GC8
3'' EXHAUST SYSTEM FITTING K
RCM STAINLESS MANIFOLD & UP
RCM MANIFOLD FITTING KIT
SAMCO BLUE INDUCTION BYPASS
SAMCO AIR BOX HOSE 78MM-73MM
STAINLESS STEEL HOSE CLAMP 7
SPARK PLUG NGK IRIDIUM FOR U
RCM INDUCTION KIT GDB NEW AG
MAPPING SESSION
PISTON RING SET EJ207/8 STD
HONE CYLINDER TO PISTON X4
OMEGA PISTON STD SIZE V7/8 G
RCM H SECTION UPRATED CON RO
ACL RACE REAR THRUST MAIN BE
ACL RACE BIG END BEARING SET
14MM/14MM WRC HEAD STUD KIT
HEAD DRILLING FOR 14MM STUDS
HEAD DOWEL FOR 14MM STUD KIT
RCM HEADGASKET MODIFICATION
HEAD GRIND
MODIFIED OIL PUMP
ENGINE GASKET SET EJ205 11/0
SILKOLENE PRO R 5 LTR 15W50
GENUINE SUMP WASHER
OIL FILTER SF5 + GGB 11/02+
BLOCK FACE SKIM GC8
this is most of the parts so far
and a lottery win
Regs
Geoff
Azyman
by wr1.305 » Tue Oct 14, 2008 7:20 pm
sounds great but means nothing to me haha, how fast dose the noise peddle make you go??? lol
MODIFIED OIL PUMP ??? how?
wr1.305
by Azyman » Tue Oct 14, 2008 8:59 pm
wr1.305 wrote:sounds great but means nothing to me haha, how fast dose the noise peddle make you go??? lol
haha dont mean a lot to me either but sounds good!!!
Regs
Geoff
Azyman
by danr55 » Tue Oct 14, 2008 9:52 pm
that's not far off a Chris/RosyB spec.
DO IT!
- Site Owner
by danr55 » Wed Oct 15, 2008 7:35 am
Geoff, what ECU is being planned with that spec?
- Site Owner
by Azyman » Wed Oct 15, 2008 11:08 am
danr55 wrote:Geoff, what ECU is being planned with that spec?
no Mention of any ECU will it need upgrade 1 then?
Regs
Geoff
Azyman
by danr55 » Wed Oct 15, 2008 11:14 am
Azyman wrote:danr55 wrote:Geoff, what ECU is being planned with that spec?
Worth asking the question, not sure if the WR1 standard ECU is up to that... I think they're good to about 400ish BHP, but not too sure....
- Site Owner
by Azyman » Wed Oct 15, 2008 12:43 pm
danr55 wrote:Azyman wrote:danr55 wrote:Geoff, what ECU is being planned with that spec?
nope its ok if i want to go any further then 450-500 then it will need to be changed result!!
Regs
Geoff
Azyman
by Megaman » Wed Oct 15, 2008 12:56 pm
danr55 wrote:Worth asking the question, not sure if the WR1 standard ECU is up to that... I think they're good to about 400ish BHP, but not too sure....
This may be a daft question but why do you need to change the ECU when you get more power??? Surely the ECU is still doing the same job of timings and fuel ratios etc... ?!
by danr55 » Wed Oct 15, 2008 5:34 pm
it's to do with boost I believe. Standard ECU can't cope with the sort of boost you'll run with that kind of power and a larger turbo. Someone more technical will give you more info. The ECU on the newer cars is better though, thankfully!
- Site Owner
by JP » Wed Oct 15, 2008 8:02 pm
Mega - also that you can get fancy bits like Launch Control and Anti Lag.
JP
by Azyman » Fri Oct 17, 2008 2:52 pm
Well The Cars Booked in with RCM
the start date is March 2009 plenty of time to save some cash
going for 450-500 BHP
must say Tim From RCM top bloke!
all the questions ive asked he has answered with ideas and sugestions to help save a bit here and there,i feel fully confident in it all
but now its a waiting game
at least its crap weather so not to bad
Regs
Geoff
Azyman
by WR1 Bro » Fri Oct 17, 2008 2:55 pm
Happy days... Very please for you. I'm sure you will be over the moon.
- Site Admin
by danr55 » Fri Oct 17, 2008 3:18 pm
Excellent stuff. What was the end result on the ECU?
- Site Owner
by WR1 WOZA » Fri Oct 17, 2008 4:45 pm
Great news Geoff
You can tell me all about it when i see u next
Good luck with the lottery win or start the saving
How much is the build Maybe discount for a group buy
WR1 WOZA
by Azyman » Fri Oct 17, 2008 5:45 pm
danr55 wrote:Excellent stuff. What was the end result on the ECU?
the one in it is ok
unless i want to go over 500 bhp lol maybe when the kids buy it of me they will
Regs
Geoff
Azyman
by danr55 » Fri Oct 17, 2008 9:07 pm
Azyman wrote:danr55 wrote:Excellent stuff. What was the end result on the ECU?
the one in it is ok unless i want to go over 500 bhp lol maybe when the kids buy it of me they will
wr1 standard ECU up to nearly 500 BHP? Hmmmmmm.......
- Site Owner
by Azyman » Wed Oct 22, 2008 11:31 am
got my new turbo today they recon it should be good for 600 BHP
let me know if you think it is ok ?
Regs
Geoff
Azyman
by rocko » Wed Oct 22, 2008 3:52 pm
Think it would be Best if you got it ceramic coated first .. should push 650 then ....
rocko
by WR 1mposter » Wed Oct 22, 2008 9:42 pm
danr55 wrote:Azyman wrote:danr55 wrote:Excellent stuff. What was the end result on the ECU?
He is correct Dan
Result Geoff, you won't find anyone better than RCM .....Young Tim is a sound bloke aswel
by danr55 » Thu Oct 23, 2008 7:56 am
WR 1mpostor (aka number 1 moderator) wrote:danr55 wrote:Azyman wrote:danr55 wrote:Excellent stuff. What was the end result on the ECU?
He is correct Dan Result Geoff, you won't find anyone better than RCM .....Young Tim is a sound bloke aswel
Fair play! I didnt realise they could cope with that power/boost but I'm sure they know what they're doing!
- Site Owner
by WR 1mposter » Fri Oct 24, 2008 9:38 am
danr55 wrote:WR 1mpostor (aka number 1 moderator) wrote:danr55 wrote:Azyman wrote:danr55 wrote:Excellent stuff. What was the end result on the ECU?
As do all tuners
by marky mark » Fri Oct 24, 2008 10:50 am
Tim came round my gaff last night to pick up a few bits, i mentioned to him that someone i knew has been saying nice things about him on the internet and he was very interested to know what and who!
- JPs little helper
by Azyman » Sat Oct 24, 2009 7:13 am
YeeeeHaaaaaaa the car geos in today at long last!!!!
Regs
Geoff
Azyman
