Users browsing this forum: No registered users and 26 guests
WR1 left it's home in the UK to roam the German Autobahn...Hi guys,
#292 has left the island and now is going to explore the Autobahn and Nürburgring region... It'll be the new compagnion of my Lancia Delta HF Integrale Evo which is at the moment in a full rebuild and should be ready in summer. Going to post some pics after the Scooby's TÜV & registration - will take some time and prep though. Cheers to all for the help & advice Micha Last edited by MikeStyles on Thu May 21, 2015 5:52 pm, edited 4 times in total.
Re: WR1 to roam the AutobahnNice work - enjoy!
Re: WR1 to roam the AutobahnFirst trip today:
Cheers!
Re: WR1 to roam the AutobahnLike I said... a good home ! Lol
Re: WR1 to roam the AutobahnNice - looks at home !!
Re: WR1 to roam the AutobahnDeleted.
Re: WR1 to roam the AutobahnWay cool - how do you find the WR1 in comparison to the EVO?
Re: WR1 to roam the AutobahnIf you are close to the Ring you should join up with this lot - I'm toying with the idea of going:
http://www.southeastscoobies.co.uk/vbul ... hp?t=19465 Prodrive - RaceDynamix 346 bhp - WhiteLine - AP Racing - Milltek - Cosworth
Re: WR1 to roam the AutobahnIan from SouthEastScoobies allready got in contact with me - we'll meet up at that weekend.
The Delta Evo is quite different - engine is more like the 2.5ltr Scoobies due to the long stroke and the supension / handling demands a lot more knowledge / experience (never brake or let off the gas pedal in a fast corner - it will spin you out). Steering feel is far better with the Deltas (very "Porsche GT3-like") and they understeer less under power if you've got an 16v Evo - and it feels a lot more compact too. Rattles and squieks all the time but that's character... Cheers! Last edited by MikeStyles on Thu Mar 19, 2015 8:38 pm, edited 1 time in total.
Do it !!!!!!!
Re: WR1 to roam the Autobahnyou must have bought Scott's car, nice to see its gone to a good home...........
not sure if he mentioned about the ECU but will try and drop you some info about some slight niggles ASPerformance
Re: WR1 to roam the AutobahnYes I did - dropped you a PM.
Re: WR1 to roam the Autobahn - finally passed german TÜVVery nice,
It is a good job you dont live in the Cochem area..
Re: WR1 to roam the Autobahn - finally passed german TÜVNice !!! Looking well !!
Re: WR1 to roam the Autobahn - finally passed german TÜVWay cool.
Re: WR1 to roam the Autobahn - finally passed german TÜV@ Big E
You're right mate - the plate would start with "COC-..." - lol!
Re: WR1 to roam the Autobahn - finally passed german TÜVOkay - end of May the WR1 get´s a prep for a remap - going to drive to the Netherlands:
http://ems-tuning.nl/ Rather famous in the western part of Germany - this will be a first "meet & greet" to evalute the Scooby and it´s setup. Awaiting a quote and opinion whether the WR1 needs a final remap (as AS Performance suggested). Keep you updated & C U soon at the Nürburgring Micha
Re: WR1 to roam the Autobahn - finally passed german TÜVHi Guys,
small update on the WR1 as we are prepping it to get it´s full potential out of it... After installing a heat-shield for the turbo to protect the intercooler and changing the turbo hoses for a Samco kit I started to build a new air deflector (the part that runs the air from the scoop into the intercooler. As a big Perrin topmount is installed it looked like this with the factory seal: If you look closely you can see the "scratches" of the factory seal on the surface of the IC so two rows on each side plus 3cm on top pf the IC weren´t in the airflow plus there was no sealing on the lower part at all. After a whole day of measuring, cutting, fitting, measuring, cutting, fitting,... etc. it ended up like this: Looks fairly strange and a little bit skew (as the IC has quite some angle regarding it's mounting points and is a bit "off" compared to the scoop) but it works rather nicely and seals perfect. And don't mind the gaffer tape - it covers the various holes from the factory seal plugs. We also reprogrammed the APEXI and next week it´s off to get a remap. Keep you updated Micha Last edited by MikeStyles on Wed May 20, 2015 3:33 am, edited 1 time in total.
Re: WR1 to roam the Autobahn - finally passed german TÜVNice work bud!
Re: WR1 left it's home to roam the German Autobahn...Hi Guys,
got the WR1 checked and remapped by the well known Subaru workshop EMS Tuning in the Netherlands - as always they detected a faulty Neutral Switch so the Intake Cam Actuator did not work... Sorted that out and after the mapping plus APEXI "wizardry" it made 450bhp at 6800rpm plus 480NM at 5500rpm. The big turbo flaws the spool-up and the total amount of torque (the real power starts at 4500rpm) but it races towards the redline and the torque stays nearly level up until 7500rpm. Cheers Micha
Re: WR1 left it's home to roam the German Autobahn...Wow big figures - is that on standard internals?
Re: WR1 left it's home to roam the German Autobahn...@WR1
Can't say really as the car has been soooo many times at different tuners in the UK since 2013 - the ECU itself has been remapped 98 times (the info can be found in the ECU) !!! But when it left the island it already made 418bhp and the APEXI wasn't really used in a proper way, the IC airduct was crappy and the IC hoses were junk... Micha
Re: WR1 left it's home in the UK to roam the German Autobahngood to see its more sorted
not sure why it had been set-up in that format possibly simply limited knowledge?? IMO would have been far better with a 3port installed and mapped to move the boost control back onto the ECU - but we had limited time and at the owners request the car was made "safe" as opposed to its previous state ASPerformance
Who is onlineUsers browsing this forum: No registered users and 26 guests |
