front brakes
General discussion about Scoobs.
front brakes
Postby markwr1 » Sat Nov 22, 2014 1:02 pm
Right guys
Early in the year I changed my front brakes.
Brembo pads
Black diamond disks.
They are shite. Never been happy with them. Don't stop well and some times horrendous wheel judder, especially when braking hard.
I guess this is cause I went cheap on the disks?
Anyways, what are peoples opinions on the best disks to use on the standard wr1 set up?
Service in a weeks tine and I want to get her sorted.
Xxx
markwr1
Re: front brakes
Postby W1 KRB » Sat Nov 22, 2014 2:55 pm
I did exactly the same a few months ago, pagid disks from euro car parts and Brembo sport pads, not performing how i wanted them to at all, also get wobble through steering wheel when they are warm, matching Brembo sport disks is my next purchase!
W1 KRB
Re: front brakes
Postby BIG"E" » Sat Nov 22, 2014 4:24 pm
Contact Alyn at AS Performance.
Ive have got Performance Friction discs and pads you wont get much better for the Brembo calliper
it never pays to buy cheap brakes as you unfortunately have found out.
BIG"E"
Re: front brakes
Postby DCFCtom » Sat Nov 22, 2014 10:14 pm
As above, PF discs and pads on mine too. Not cheap granted but luckily ive only had to pay for new pads as the previous owner shelled out on the discs
DCFCtom
Re: front brakes
Postby markwr1 » Sat Nov 22, 2014 10:18 pm
How do the p f disks compare price and performance wise to the brembo disks?
markwr1
Re: front brakes
Postby BIG"E" » Sun Nov 23, 2014 11:53 am
markwr1 wrote:How do the p f disks compare price and performance wise to the brembo disks?
I don't how how they compare with brembo discs,
What I do know is that they are better than the OE ones (not sure if they made by Brembo) and cheaper.
So if you need to replace your discs it is cheaper to buy PFs and an upgrade, rather than replacing with OEs
BIG"E"
Re: front brakes
Postby W1 KRB » Sun Nov 23, 2014 1:59 pm
Looks like £600 for a pair Of front disks for the pf to me!
W1 KRB
Re: front brakes
Postby Willowsdad » Sun Nov 23, 2014 3:51 pm
Haven't you got 2 piece discs big 'E'? Nice but pricey. I seem to be having the same problem with brake shudder. Had new godspeed discs in April after assuming the Pagid discs were warped, but the issue still seems to be there. Godspeed offered to take the discs back and check them, but it's a pain having to take them off and send them back.
Willowsdad
Re: front brakes
Postby markwr1 » Sun Nov 23, 2014 4:33 pm
You can get brembo disks for under 300 for the pair and even brembo sport disks for a little bit more. Gonna take a chance on those I reckon.
markwr1
Re: front brakes
Postby W1 KRB » Sun Nov 23, 2014 4:36 pm
I'm thinking the same tbh, will be speaking to alyn at as performance very soon, keep us informed how you get on
W1 KRB
Re: front brakes
Postby BIG"E" » Sun Nov 23, 2014 6:26 pm
Willowsdad wrote:Haven't you got 2 piece discs big 'E'? .
Yes I have and they are worth every penny..
I bought them from AS Performance..
BIG"E"
Re: front brakes
Postby marchar » Sun Nov 23, 2014 7:32 pm
I purchased a set of Brembo drilled discs and I think they were fast road brembo pads, they work really well, I'd recommend getting some updated brake hoses too ! Got mine from Alyn at as performance too, he's a nice chap and will take the time to go through it with you.
Hope it helps with your choosing :wink:
marchar
Re: front brakes
Postby Gary75 » Tue Nov 25, 2014 7:59 pm
Brembo HP pads from Alyn As Performance. Previous pad Ferodo DS 2500 both pads seem similar in performance but really to early to judge as I don't use the car that often. I can conclude no shimmy is evident with the Brembo pad so less dust build up?
Re: front brakes
Postby paulscooby » Wed Dec 17, 2014 8:18 pm
Hi all
you could always get discs skimmed had this done on 368 new pads absolutely sorted brakes like new no wobble etc , had this on previous sti turned
out to be buckled front wheel rotated to back sorted .. :wink:
paulscooby
Re: front brakes
Postby markwr1 » Thu Dec 18, 2014 9:03 pm
Put the brembo sport disks on three nights ago. Mustard. Like a new car. I can not believe the difference in them.
I will never buy chez again!!!
Awsome
markwr1
Re: front brakes
Postby W1 KRB » Fri Dec 19, 2014 7:01 am
So you kept original pads? Have you got them warm yet to see if they judder at all?
W1 KRB
Re: front brakes
Postby markwr1 » Tue Dec 23, 2014 11:01 pm
Yes I kept the brembo pads in.
I am well impressed. No complaints at all. I am going to give it some grief now they have been bedded in and i will let you know the out come.
They seem to be very, very good.
markwr1
Re: front brakes
Postby Gary75 » Wed Dec 24, 2014 3:46 pm
Reading some posts on other forums seems to be a common problem front brake judder.
If the discs aren't fitted true then judder will be expected after a couple of thousand miles.
I had this problem with DS pads but have not experienced with the Brembo sport pad, although I don't use the car that often I do get some build up on the discs which can cause judder when braking, once cleaned off after a couple of applications all seems well.
I would give the car some heavy braking to clean any shit off the pads and discs, before condemning
Re: front brakes
Postby Grant74 » Mon Jan 19, 2015 12:58 pm
Have used godspeed discs on rally car for last 6 years and only just changed them, with Brembo's on.
Have only just changed them as a precautionary measure- fair bit cheaper than PF and not sure much difference
Grant74
Re: front brakes
Postby asperformance » Wed Jan 21, 2015 9:14 am
no offence to GS but there is a MASSIVE difference between genuine PFC rotors and other offerings in our experience
first and foremost they are fully heat-treated directional rotors
Return to General Scooby Chat
Users browsing this forum: No registered users and 82 guests
