time for brake pads?
Postby weirdfish » Tue Oct 14, 2014 2:58 pm
Car is in having a new exedy clutch fitted, I also asked my local guy to look at the brakes, ( felt very wooden to me ), he's come back to say that the rears are very low, but the fronts are fine, ( although they are EBC red stuff ).
My understanding of Subaru brakes is that they are not as "servo assisted" as a lot of cars and therefore you have to use them a bit heavier, ( if that makes sense ), but also, would the "red stuff" pads magnify this to some degree.
If this is correct can you suggest a decent road pad that will work when I want it to.
weirdfish
Re: time for brake pads?
Postby Gary75 » Tue Oct 14, 2014 5:17 pm
I've just fitted Hp Sport pads, not yet run in but seem to work fine.
My previous pads were Ferodo DS2500 which again worked well but gave some shimmy after a couple of enthusiastic applications.
Both pads give good firm pedal feel.
Speak to Alyn AS performance he will point you in the right direction
Postby Azyman » Tue Oct 14, 2014 9:03 pm
Pf pads are good. I had them fitted to my one they worked great.would recomended
Regs
Geoff
Azyman
Users browsing this forum: No registered users and 55 guests
