Blip in 3/4th when giving some beansHappened a couple of times now when I'm putting foot down on motorway or dual carriageway in 4th or 5th (not both but can't remember which) it has a little hick up at 5/5.5k. Loosing acceleration for a second & then back to normal. No bangs just the hick up & the emissions light comes on dash.....any body had same problem or know the cause? Doesn't do it driving around town only when powering through gears on motorway
Re: Blip in 3/4th when giving some beanshiya bud just wondered if you had it remapped after you put the decat on , or it could be that noisy dump valve you've got on causing a loss of air putting a warning light on
Re: Blip in 3/4th when giving some beansHi pal, no didn't have it mapped with decat just a resistor fitted to prevent lights on dash. I'm not sure it will be dump valve it does it at 5/5.5rpm powering through, I was under impression that dump valve only working when you let off throttle to release boost pressure were I had foot planted. Might have to just take it to specialists
Who is onlineUsers browsing this forum: No registered users and 18 guests |
