Users browsing this forum: No registered users and 50 guests
nur spec r exhaustin need of a bit of help, i have acquired a nur spec r back box. does anyone know what sort of center section i need to make it fit???..... am i right in thinking i need a 2.5" at the front and 3" to connect the backbox.
Re: nur spec r exhaustNot sure mate, I recently got the same fitted at autotecnica so may be give them a call. I hope you like loud mate mine sounds awesome
Hi there bud, what did thy do for you?????
Re: nur spec r exhaustThey fitted a used one they had for sale, it already had the middle section so it was just a case of unbolt the old and fit the new from the cat back. Good blokes mate give them a shout they may be able to help
Cheers will do , thanks
Re: nur spec r exhaustNo problems hope you get it sorted
Re: nur spec r exhaustHello mate did you get this fitted??????
Re: nur spec r exhaustbooked in at deemon tweeks near wrexham, their exhaust guy is going to make the spec r into a spec s, unless they can modify a 3"center section for meas blitz flanges are at more of an angle!!!
Re: nur spec r exhaustJust an update on this......
Went to tweeks and the guy their cut the flange off the spec r bolted it inline with my mid section the aligned the backbox to the flange and re welded the pipe. So now I can fit any 3" mid section ( getting one after Christmas ) Blitz rotate their flanges so they're about 10-15mm out of plonk with Subaru flanges, other than getting the backbox from a friend cheap minus the mid section and then after contacting blitz to try and get a mid section from them and being told bluntly ..NO!.... I wouldn't touch or use their products due to the lack of customer support from them. So if you have the nur spec r exhaust and somehow the mid section got damaged..... Blitz just expect you to roll over and just shell out another £600 for another exhaust
Who is onlineUsers browsing this forum: No registered users and 50 guests |
