Heat shield problem after decat help??
Postby Super si » Mon Mar 11, 2013 4:43 pm
Had a decat fitted by scooby clinic recently & after a week my steering wheel was getting wedged when turning right, took to local garage & a heat shield was loose & rubbing against my steering in engine. Apparently it's because when they take standard cat off this heat shield bolts to it. Has anyone else had this problem & what did you do? My local garage tightened bolts back up & tried to bend bracket out of way but still hitting. Anyone removed it? Is it the up pipe heat shield?? Easy to take off cut & put back on? Off the Tfs at weekend & need to get sorted :cry:
Super si
Re: Heat shield problem after decat help??
Postby asperformance » Tue Mar 12, 2013 8:54 am
you would normally remove the lower one and re-shape the upper...........
no idea why your fitter hasn't done this originally???
Postby Super si » Wed Mar 13, 2013 12:43 pm
asperformance wrote:you would normally remove the lower one and re-shape the upper...........
Re-shape upper...that turbo heat shield?
& remove lower is that the up pipe shield easy to get to? Im off to tfs on sat & its causing me problems at min so trying to sort it
Super si
Postby Super si » Wed Mar 13, 2013 5:49 pm
Think I have sorted it, jacked it up today. There's a bracket that's spot welded to the heat shield that was touching knuckle joint on steering so bent it out of way hopefully will stay in place
Super si
Users browsing this forum: No registered users and 24 guests
