Users browsing this forum: No registered users and 38 guests
whats the best oil for the wr1my car is due for its 50000 service and i wanted to know whats the best oil for the 1 as the local subaru dealership has done the last two services and i think they have used cheap oil. what are you lads running in your car ?
Re: whats the best oil for the wr1Fuchs Titan race pro s 5-40 synthetic in my standard power 1, recommended by opie oils
Re: whats the best oil for the wr1same as above, I did Use millers v300 the time before that but it didnt like it on a few cold mornings, The fuchs has been great even after a week without use
Re: whats the best oil for the wr1Millers 10/50 as supplied and recommended by Alyn at As Performance..
Give him a ring for all your needs ..
Re: whats the best oil for the wr1Marchar i think you mean MOTUL 300v.............a lot depends on actual grade used, mods, etc.
Fuchs is a much lower quality than the Millers CFS and particuarly than the new Millers CFS NT and Motul 300v........... ASPerformance
Yes i use the same, but in addition i use a magnetic drain plug and 6 small maganets around the filter. Hope this helps?
Re: whats the best oil for the wr1thats the kiddie alyn, Motul 300v, The grade was 15- 50, Just rattled a couple of times when started from cold for a second or so
It was expensive, I think I paid about £120 for 6 litres and didnt even do 5000 miles on it Probably got the wrong grade or somthing? Maybe I will try the millers next oil change Nobody told me it was this brutal !
Re: whats the best oil for the wr115w50 is far more suited to a classic or heavily modded scoob.........
if you paid £120 then you bought it from the wrong place.......... ASPerformance
Re: whats the best oil for the wr1I'm going to dig the receipts out and see what it cost,
6 litres cost me £97.59....... ? Nobody told me it was this brutal !
Re: whats the best oil for the wr1I run my modified car on millers 10w60
Re: whats the best oil for the wr1to save a few PM's, etc......
we supply/use both Millers and Motul competition oils (and their full range if needs be) and have done for the past 12yrs+.......... we always have price reductions on and will happily beat or match any other genuine quote BUT as a general rule our "normal" prices are cheaper than most others "specials" carry genuine filters, etc. in stock and will happily post World wide if needs be ASPerformance
Re: whats the best oil for the wr1I'll give you a tinkle when the time comes, I'm also nearly up to full in my brakes bank too
Who is onlineUsers browsing this forum: No registered users and 38 guests |
