what BHP with a TMIC ?
Postby mikethatcher » Sun Sep 30, 2012 3:19 pm
I was wondering who has the most BHP with a top mount ? I hear that 400 bhp is prob the most you can go. I want to get somewhere near that but without the extra expense of a FMIC. ....
mikethatcher
Postby asperformance » Mon Oct 01, 2012 9:19 am
a certain mr.forest has nearer 500bhp and over 500lbs/ft on his road going 2.5lts spec-C.............
Postby mikethatcher » Mon Oct 01, 2012 11:28 am
asperformance wrote:a certain mr.forest has nearer 500bhp and over 500lbs/ft on his road going 2.5lts spec-C.............
:shock: That's much more than I
expected. Good to know that.
mikethatcher
Postby Megaman » Mon Oct 01, 2012 11:35 am
The TMIC is good for high power levels and if you look at the distance the pipework goes its about 3 inches or so. a FMIC means you have the lag of the air having to go all round the additional pipework to the front of the car. FMIC better if stuck in traffic suffering heat soak. Better for a lot of track work.
Postby chiroman » Mon Oct 01, 2012 1:41 pm
Iain Litchfield's Type 25's are 415bhp with a TMIC, although with a Cosworth engine. I think his T20's were about 350bhp. I guess you need an output which also gives reliability too. Is 400bhp on a std engine a reliable aim?
chiroman
Postby Megaman » Mon Oct 01, 2012 9:56 pm
Luck of the draw when you mod to that level, I know 5/6 people running 400ish bhp on the standard 2L engine without any issues. I also know several that have had issues including mine so its anyones guess :)
Postby davetwr1 » Tue Oct 02, 2012 6:21 pm
hi mega what have you done to your 1 mate
davetwr1
Postby WR 1mposter » Thu Oct 04, 2012 7:45 pm
Had 360 bhp with a stock tmic and turbo car drove like shit due to surge.
Fitted a bigger turbo and a aps tmic got 385bhp, but also fitted fuel lines, fpr, and so on but the drive was so much better.
but you will not get 400bhp with standard turbo/2.0ltengine
Postby asperformance » Fri Oct 05, 2012 7:42 am
to clarify its the std vf35 turbo that is the limiting factor..........nothing else
Users browsing this forum: No registered users and 47 guests
