Bonnet Dampers fitted!
Postby Steveyk » Wed Jun 13, 2012 5:21 pm
Dampers received and fitted today, cheers Gary :D
They work a treat! Was going to fit just one with the aluminium bonnet, but they seem to be calibrated right anyway. Maybe this is just me being thick. After two or three shuts they work together and lift it square.
Steveyk
Postby Gary75 » Wed Jun 13, 2012 7:00 pm
Thanks for the reply, they look very nice. Glad to be of service :D
That engine bay looks perfect :thumb:
Postby delrodney » Thu Jun 14, 2012 7:40 pm
sorry, only just seen this after posting! :oops:
looking good.
Trev
Your ego is writing cheques your body can't cash!
WR #47
delrodney
Postby Steveyk » Thu Jun 14, 2012 8:44 pm
Peice of cake mate, took all of 15 minutes! 12mm socket for the bonnet, and a deep 10mm one for the nuts/ball joints on top of the wings. Line everything up, tighten the 12mm bolts back up with the shakeproof washers underneath, screw the ball joints into the thread in the wing (after you've taken the bolt out of course!) , insert the wire clips to stop the damper popping off the ball joints, job done!
Steveyk
Postby Matty WR1 » Thu Jun 14, 2012 8:48 pm
That looks minty fresh, love it :)
Matty WR1
Postby Gary75 » Fri Jun 15, 2012 4:39 pm
Mine fitted today....
Old bonnet stay now removed, these dampers work perfect. So if you require a set PM your details.... :thumb:
Postby delrodney » Sun Jun 17, 2012 6:09 pm
fitted mine today and really pleased.
15 mins to fit??? :shock:
took me an hour! :lol:
those securing clips for the ball joints were a nightmare.
Trev
WR #47
delrodney
Postby Gary75 » Sun Jun 17, 2012 6:54 pm
delrodney wrote:fitted mine today and really pleased.
Yes them small clips are the bug bare and nightmare, had to modify the angle so though would pass through the last small hole.
Im going to source a different upper clamp so both bolts are used to secure upper ball joint, would be less flex and would fit better than the adjustable clamp supplied with the dampers.
Users browsing this forum: No registered users and 36 guests
