Invisible Touch Detailing - The Do Luck Supra
Postby InvisibleTouchDetailing » Fri May 18, 2012 12:04 pm
(This writeup was written for the Mkiv Supra Club, hence some of the naming)
Here we have Jamesy's writeup for his newely acquired Do Luck Supra!
The car was booked in for a Stage 1 paint enhancement, so not all defects will be removed in this process. As a general rule original Supra paint is quite soft, as this car has been fully painted it was a little unknown what the paint hardness would be like. I can tell you now, that its much harder :)
So, taking a walk around the car lets see what weve got...
Starting off, the tyres were cleaned with All Purpose Cleaner
Wheels with Bilberry, which is safe for all types of alloys, including chrome
Calipers also cleaned with APC
All door, boot, fuel shuts, window trim, lights and scuttle panel cleaned with APC
The car was then jetwashed, snowfoamed, rinsed off after 5 mins and washed using Shampoo Plus, leaving this
Being a mild day outside, the car was clayed using Last Touch as lube to remove bonded contamination washing would not remove
The rear number plate was cleaned with Tar & Glue to remove the residue from a previous plate applied over the top
After being washed again the car was taken inside to be dried and inspected, lots of swirls and faded paint was now very apparent
Paint thickness readings were taken. Obviously being painted the levels were noticeably higher than you would expect for original paint
I chose to use Meguiars M205 polish, a 3M polishing pad and backing plate and the Makita rotary. Each panel required 2 hits of this process to achieve the results i wanted the car to leave with for a stage 1 treatment. The defects remaining would require a step up in compound to remove, which would need a stage 2 correction treatment. As the defects that remained had the edges taken off them during the process applied here, this hugely changes the way natural light hits them, and as you will see as the car develops, this will still leave an exquisite finish to the vehicle
Starting on the front wing
Moving onto the door
The rear wing
The blades of the carbon spoiler had to be removed to allow the machine full access
Moving round to the other side
Onto the passenger door
Polished side under LED light
Unpolished side
Passenger front wing had some lovely defects clearly visible
Round to the bonnet and then front bumper
Then the A pillars and roof
The carbon spoiler was also machined
Once all polishing was complete, and all panels had been IPA'd to remove polishing oils, out came the box of Do Luck stickers to return the original graphics the car was known for. Each sticker location was carefully checked to its original place
The glass was then cleaned using 3M Glass Cleaner
The exhaust was polished inside and out
Swissvax Cleaner Fluid was then applied by hand to the paint to prepare it for the wax application
The chosen wax, was Swissvax Best of Show. Applied in a thin layer and buffed off after 15 mins
The wheels, although really requiring a refurb, were polished up with NXT, ipa'd and sealed with Poorboys. Tyres were dressed with Endurance Gel
The boot was hoovered and everything cleaned with APC
The interior was hoovered and dusted down
These were the final pictures after window seals and scuttle panel treated with Bumper Care
Finally the car was wrapped under a sheet to await Jamesy's arrival
When he came, we both applied the Do Luck sunstrip, as best we could :) This wasnt an easy task!
These were the final pictures as the car was pulled outside to leave
It was a great pleasure, to work on the Do Luck Supra, and for Jamesy. He's a fantastic guy that will do the car proud, for us all to appreciate back in UK events.
Thanks for reading,
Christian
INVISIBLE TOUCH DETAILING
Automotive & Marine Detailing Treatments
Web: http://www.invisibletouchdetailing.co.uk
Email: christian@invisibletouchdetailing.co.uk
Phone: 07876 166 077
Postby Chris B » Fri May 18, 2012 2:53 pm
Top work as always,good write -up.
Chris B
Return to Car Care
