Alarm code
Alarm code
Postby Dayo » Sun May 06, 2012 9:54 am
Where can i find my alarm code incase my key battery ever goes flat?
Iv looked through all my booklet and service book and cannot see it anywhere!
Finally Got My Hands on a WR1 #039. Loving it ;)
Dayo
Postby Gary75 » Sun May 06, 2012 12:30 pm
Trackstar Folder
Should be with your Trackstar folder documents in a small plastic bag marked "to be opened by dealer only" The contents include.
1 x metal tag on key ring with number stamped on tag. This will enable dealer to supply replacement keys.
1 x small silver sticker with pin number for alarm, this is contained in small plastic bag
1 x Subaru credit card size trouble shooting guide for alarm system
1 x Certificate of compliance category one alarm signed by Subaru, contains information vin, alarm evaluation, alarm ecu serial number etc.
1 x Trackstar certificate of installation
1 x Trackstar user guide
In my Leather case
1 x Service book
1 x owners manual
1 x Cat 1 Alarm system operating instructions
1 x WR1 performance pro package registration card
1 x SRS airbag system "what you should know"
1 x Subaru assistance manual
And 1 x style plastic CD case for tax disc holder contains fitting instructions 2 x small alan keys to unscrew tax disc and 5 x spare mounts
CD cover has WR1 Sti / Subaru on front cover
All above should be with the vehicle.
Hope this helps :wink:
Postby Dayo » Sun May 06, 2012 12:35 pm
I have non of that. I have 2 keys which 1 has never been used which has a small silver sticker on the back. It has a 4 digit number.
How would i try to see if the code is correct?
Dayo
Postby Gary75 » Sun May 06, 2012 12:38 pm
Dayo wrote:I have non of that. I have 2 keys which 1 has never been used which has a small silver sticker on the back. It has a 4 digit number.
The silver sticker with code maybe alarm code, shouldnt be stuck on keys though :shock:
Speak with the last owner you need all the other docs as verification of alarm etc, plus you need the key ring with code stamped to order new keys.
Postby Gary75 » Sun May 06, 2012 12:43 pm
Set the arm as normal via the fob, then manualy unlock the car, the alarm will sound pull down the tray punch in the four digit code, the alarm will stop if the code is correct? The code can also be changed to a number you will remember.
Postby tomwrx » Sun May 06, 2012 1:31 pm
PM sent :wink:
07wrx sl Fast Enough
tomwrx
Postby Gary75 » Sun May 06, 2012 7:31 pm
Gary75 wrote:Trackstar Folder
In my Leather case
1 x Service book
1 x owners manual
Dayo did you manage to attain the above products from previous owner :?:
Postby Dayo » Sun May 06, 2012 7:35 pm
no but iv been pm'ed by a member on this forum with the instructions on how to reset the pin code to whatever you want without the previous pin.
you must have a working key though.
i have the alarm booklet which tells you how to change options on the alarm. and i have the alarm certificate. just dont have the 2 stickers with the factory code on.
so iv set it to my very own code :)
Dayo
Postby tomwrx » Sun May 06, 2012 7:36 pm
glad u got it sorted mate :wink:
tomwrx
Postby Dayo » Sun May 06, 2012 7:37 pm
cheers, it wasnt a problem, but it would of been a problem if a had been out and the battery in the key had gone flat!
:evil:
Dayo
G
Postby R1ynb » Sun May 06, 2012 7:38 pm
Good wrk Tom :)
R1ynb
Postby tomwrx » Sun May 06, 2012 7:40 pm
only happy to help :D
tomwrx
Postby Dayo » Sun May 06, 2012 7:40 pm
ah yes it was tom!
yeah it didnt work first time, maybe i pressed the wrong button haha. you cannot tell if youve pressed it or not lol
got there in the end ;)
Dayo
Postby marchar » Mon May 07, 2012 10:25 am
thats encouraging, can you pm me the info too tom?
Would be much appreciated
8)
marchar
Postby CAVEMAN » Mon May 07, 2012 11:03 am
probably a useless post here... but there was a link posted up sometime ago with a link to download the alarm stuff.
covers changing numbers, codes to activate different settings etc...
was called Sigma M30 codes or something.
Postby tomwrx » Mon May 07, 2012 11:20 am
yes thats just the normal stuff that can be found on the net,
scoobypedia has it on,info is for setting bleeps on for locking car,valet mode,adding other fobs etc.
the info i passed on is for people who have lost the pin numbers and allows them to reset the system and choose there own number, :wink:
this isnt common knowledge and something i wouldnt openly post on forums!!! :shock:
tomwrx
Postby Dayo » Mon May 07, 2012 12:16 pm
yeah i dont think its a good idea giving it out unless someone really needs it.
it could cause people to reset other peoples pins to try and steal the wr1. but it would still need hot wiring or a replica key cut!
Dayo
Postby tomwrx » Mon May 07, 2012 12:20 pm
totally agree mate thats why i pm'd you. :wink:
saves 50-75 quid from the stealers to do it.
tomwrx
Postby Dayo » Mon May 07, 2012 12:26 pm
im very greatfull for you sending me it :P
i was cra**ing myself incase it went wrong and neither key worked to disarm the alarm haha! i would of never got it started again! :oops:
Dayo
Postby tomwrx » Mon May 07, 2012 12:28 pm
lol yeah its always scary when doing things your not 100% sure of, but you got there in the end, thats all that matters 8)
tomwrx
Postby CAVEMAN » Mon May 07, 2012 2:23 pm
tomwrx wrote:yes thats just the normal stuff that can be found on the net,
In that case bud, can you PM me too?
Not sure if I have any codes at all, but have changed battery twice and was left without one for a few weeks during some work I did on it. Never had to use the keypad, but always good to be safe!
Postby tomwrx » Mon May 07, 2012 3:23 pm
PM sent :wink:
tomwrx
Postby marchar » Mon May 07, 2012 9:48 pm
thanks tom, u r a good man :wink:
marchar
Postby Micktype WR1 » Mon May 07, 2012 10:22 pm
Thanks Tom.
Just had your pm.
:wink:
Micktype WR1
Postby tomwrx » Mon May 07, 2012 11:16 pm
no probs lads,
happy to help :D
tomwrx
Postby Venkman » Thu Jun 28, 2012 10:20 pm
Hi Tom can you pm the info to me too please. I think I might have the code but not sure where lol and want to personalise it anyway. Have both my keys though. Much appreciated if you could
Venkman
