Hi,
Today, Shane (MkiV Supra Club) has collected his car after i carried out a Stage 1 paint enhancement (so not full correction) and engine bay treatment. As with all of you i have dealt with, Shane is once again another cracking guy and it was a pleasure to meet him and his Supra. However, time for some pics, and there's quite a few so go and grab a beer
This was his Supra on arrival (Shane does not have a problem with his plates being shown)
Taking a walk around the car
To start off, the induction kit was covered and the engine lightly sprayed with the pressure washer turned off (minimal water) Areas were then sprayed with meguiars all purpose cleaner, engine and machine cleaner and then aggitated with a selection of brushes. It was then carefully rinsed off.
As was the fuel cap
The door shuts
And then the boot shuts
The tyres were then sprayed with all purpose cleaner and aggitated
The wheels went through the same process using bilberry
At this point the weather was starting to turn. So the car was jetwashed down, snowfoamed to loosen the dirt and left to dwell for 5 mins and then jetwashed off. The Supra was then washed using the 2 bucket method using meguiars shampoo plus. It was then taken into the garage to be clayed to remove the bonded contamination
It was then washed again outside using the 2 bucket method and brought back inside. Whilst the engine bay was still wet, everything was sprayed with aerospace 303 and left to dry naturally
Bonnet closed, we'll come back to that later
The car was dried using drying towels and then the paint was measured. A few areas measuring less than expected but not that caused any major concern. Now to give you an idea of thickness's involved on the gauge, this plastic card measures 127 microns
Inspecting the paintwork under halogen lighting revealed this
I normally like to use menzerna 106fa polish for a task like this, but chose to use meguiars #80 with the makita rotary, 3m polishing pad and 3m backing plate for control
Working my way around the car
Onto the passenger door
A quick inspect under led lighting
Continuing around
The sunlight catching the rear wing
Once all polishing was complete, i returned to the engine bay which had dried lovely with the water and 303 mix. The paintwork in here was wiped clean and dusted down
After an ipa wipedown on the paintwork to remove polishing oils, it was then treated with dodo juice lime prime lite glaze / pre-wax cleanser to prepare the paint to recieve a wax and aid bonding
I then applied 1 application of victoria concourse wax
All glass was polished and the exhaust was also polished using meguiars nxt
The scuttle panel was treated with bumper care and applied with a brush which i find the best way due to its shape.
The alloys were treated with wheel sealant
And tyres with 2 coats of endurance gel
The tyre pressures were then also checked and inflated to Shane's requirements
The interior was dusted, hoovered and wiped down with all purpose cleaner
These were some final shots
Before being covered up ready for Shanes arrival
The final task was to complete his service book to go along with his existing maintenance records
Just before Shane drove out the gate, i snapped a few outside shots
Shane's reaction was smashing to say the least and makes the many, many hours involved even more of a pleasure. Hope you enjoyed the read
Christian
Users browsing this forum: No registered users and 15 guests
