Users browsing this forum: No registered users and 47 guests
cleaning engine bayguys , looking for some tips for engine bay ,,Im a bit scared of using a preasure washer , and wasnt sure about a steam clean ??? any advice welcome
Bag your alternator, battery... Spray with engine degreaser, tickle with a brush and wash off with gentle stream of water. No need for pressure.
Dry with cloth and spray with protector. Doesn't take long.
Wise words Bro, warm up the engine, any electrical connector cover off with kitchen foil. Degreaser applied and "tickled" I use hot water supply to my pressure washer (on low pressure) avoiding direct contact with the foil, let dry completely and finish off with Aerospace 101 (got mine from polished bliss). The results are astounding and never had a problem with the electrics. Good luck.
I put off doing this for ages as I was worried,but followed tips from you friendly bunch and other forums and was made up with the outcome!! Well worth the bum twitching moments as you apply water to the engine !!!
When you wash your engine for the first time you do feel relieved when the car then starts.
cheers guys , Im gonna check the size of my balls when I get home , and if there a decent size Il go for it ,, then Il try cleaning the engine
Good man.. A picture before and after of your Bollox( as well as engine) would be interesting hahahahaha
yes leave it with me , although Ive only got a 5 megapixel camera
come on fella's...its a sealed metal box.
you gotta be really unlucky to actually do any damage or short anything out. Just use common sense and take it easy over any connections and exhaust wrapping you may have on. Always start asap and leave it to run for a bit to then evaporate any water puddles left over and get it out of the spinning bits. Then apply your protectant, sit back and enjoy.
Who is onlineUsers browsing this forum: No registered users and 47 guests |
