De-tangoing lights
De-tangoing lights
Postby WillyWonker WR1 » Sat Jul 23, 2011 2:32 am
Hi, ive heard about de-tangoing ur head lights and theres alot of different ways of doing it but i need a good step by step guide, im abit worred about doing it as i dont want to get misty head lights after lol, any advice would be helpful :) :) :)
WillyWonker WR1
Postby grahampesking » Sat Jul 23, 2011 9:41 am
grahampesking
Postby WillyWonker WR1 » Sun Jul 24, 2011 11:23 am
Cheers for that m8, I'm just so scared to do it lol but I think it would look s@*t hot on my WR1
WillyWonker WR1
Postby grahampesking » Sun Jul 24, 2011 5:37 pm
yeh Ive not done it yet either , going to give it a go in a couple of weeks ,, worst case senario , just go to the garage with ur fu@kd up lights :lol: :lol:
grahampesking
Postby MaverickUK82 » Sun Jul 24, 2011 10:30 pm
I'd recommend getting some decent black sealant and resealing after taking them apart.
Postby CAVEMAN » Mon Jul 25, 2011 8:52 am
you only need to warm then up to soften the mastic...so NO oven required.
I used a heat gun that I use for heatshrinking cables, so not quite as hot as a paint stipper gun.
Just make sure you take out all the tiny screws that keep the 2 halfs together, and prise apart slowly working the heat gun around. If you can clean it all off the new mastic is the way to go, but if not then don't worry too much. Just make sure your in a clean and dry place when you do it.
Postby WillyWonker WR1 » Mon Jul 25, 2011 4:34 pm
so im just taken the front lens off the lights and popping the mastic off and reapplying or is it safer trying to keep the same mastic on and maybe getting mist on the inside, all the help im getting very very helpful peeps :D :D :D :D
WillyWonker WR1
Postby brenmyster » Mon Jul 25, 2011 5:54 pm
Did mine today took about 2 and a bit hours. Took front grill off as this made it easier to get to a 10mm bolt that holds front of light within a plastic holder..
Used a hair dryer to soften mastic....did passenger side first then drivers side was a lot quicker....Had a bit of a game trying to get the orange triangle out.Had to undo the tiny screw in the lens area and pull it out from the top....
Thanks to Rocko for the link and also the tips on text. :D
Makes the car look sooooo better IMO :D
Regards and be lucky !
Simon
#226
brenmyster
Postby WillyWonker WR1 » Mon Jul 25, 2011 6:08 pm
Brenmyster, what bulbs r u now using for the orange now u have de-tangoed her
WillyWonker WR1
Postby SteveS » Mon Jul 25, 2011 6:14 pm
Luv the way it changes the look of your wheels as well. :D
SteveS
Postby brenmyster » Mon Jul 25, 2011 6:20 pm
I used these.....probably get them cheaper if you shop around but I couldn't be arsed
:D
http://www.priracing.com/product.php/17 ... ulb--pair-
Simon
#226
brenmyster
Postby brenmyster » Mon Jul 25, 2011 6:22 pm
Posted: Mon Jul 25, 2011 6:14 pm Post subject:
Haha :D
Simon
#226
brenmyster
Postby SteveS » Mon Jul 25, 2011 6:33 pm
I soooooooooooo like the look of the "black" wheels but want to keep my wheels as standard, the devil on my shoulder says do it, luckily I have two........I am so gutless :?
SteveS
Postby WillyWonker WR1 » Mon Jul 25, 2011 6:41 pm
same as me then SteveS :toofunny: im still gutless to do me lights but i will lol
WillyWonker WR1
Users browsing this forum: No registered users and 32 guests
