car pulling to the right
Postby mikethatcher » Sat Jun 11, 2011 5:12 pm
Anyone help ? when i accelerate the car pulls to the right, when i ease off it pulls back to the left, ive had the basic tracking done and it was towing in by 2%. had that done but still the same :cry:
mikethatcher
Postby Crockel » Sat Jun 11, 2011 5:43 pm
Alignment sounds the most likely. I had the full set up when my car was last in for a service and was amazed how much it improved things. You ideally need a Subaru specialist or a decent alignment centre to do it for you. I would probably avoid the majority of the 'national chains'.
Crockel
Postby mikethatcher » Sat Jun 11, 2011 5:50 pm
Thanks Crockel , Alignment is my first port of call then. I know a good local garage that does geometry testing.
mikethatcher
Postby Megaman » Sat Jun 11, 2011 7:36 pm
Do the works on the wheels:
-balance all 4 wheels
-laser geometry 4wheel alignment
-tracking
should correct all your problems or at least highlight if there is a problem somewhere.
Postby mikethatcher » Sat Jun 11, 2011 8:15 pm
Thanks for all the advice, will let you know the outcome. didnt think about the wheel balance, had new tyres about 3 months ago.
mikethatcher
Postby Megaman » Sat Jun 11, 2011 8:24 pm
missed off my list to check tyres wear is even i.e. you havent got 4mm on one side and 7mm tred on the other side - makes a big difference if u have a puncture and stick a new one on
Postby WR 1mposter » Sat Jun 11, 2011 9:47 pm
Mike I've got some geometry sdetting for fast road somewhere will try to find it for you !
Postby WR 1mposter » Sat Jun 11, 2011 10:03 pm
Postby Daz » Sun Jun 12, 2011 8:53 am
hi sounds more likely you have a worn bush or something loose allowing your wheel to pull forward under acceleration and fall back when you ease off .
Daz
Postby mikethatcher » Sun Jun 12, 2011 10:19 am
I looked at the front bushes, off side did have very slight movement. will try geometry first, hopefully it will sort it, if not new bushes required.
Thanks Martin for the settings aswell.... 8)
mikethatcher
Postby WR 1mposter » Sun Jun 12, 2011 6:07 pm
mikethatcher wrote:I looked at the front bushes, off side did have very slight movement. will try geometry first, hopefully it will sort it, if not new bushes required.
Mike just remebered yoiu haver o.e. suspension, so best not use the geometry setting as severe, perhaps 1.5 on the front 1.0 on the rear
Postby asperformance » Tue Jun 14, 2011 8:10 am
just a daft one but are all of your pressures correct?? this is often over looked.......
Postby MaverickUK82 » Tue Jun 14, 2011 11:27 am
I remember seeing an email on this site somewhere from someone from Prodrive, to Subaru, with the correct and specific geometry settings for the WR1 - anyone know where it is - has a quick browse and not finding it...
Postby CAVEMAN » Tue Jun 14, 2011 12:31 pm
MaverickUK82 wrote:I remember seeing an email on this site somewhere from someone from Prodrive, to Subaru, with the correct and specific geometry settings for the WR1 - anyone know where it is - has a quick browse and not finding it...
I think that was Mega, and getting KT Green to confirm the geometry from Prodrive.
There are lots of different topics and each person has their own preference to the settings. IMHO the standard ones are not the best for out and out handling, not agressive enough on the front turn in for me.
Postby Megaman » Tue Jun 14, 2011 3:47 pm
Still got the prodrive settings i got charged for if you want them?
Postby mikethatcher » Tue Jun 14, 2011 4:36 pm
Megaman wrote:Still got the prodrive settings i got charged for if you want them?
That would be helpful, thanks
mikethatcher
Postby Cozzy 481 » Tue Jun 14, 2011 8:32 pm
Sounds like Mega is gonna want some dosh for the info!! :lol: :lol:
Bmw 320ci msport
Bmw 323i tour msport
Subaru Impreza wrx sti 03 (new)
wr1 481 (New)
Bmw 530i m sport (Champane Edition)
Shogun (06) SORRY
Bmw 330i m sport
Bought WR1 481 back.(SOLD)
Subaru Tribeca B9 SE7 2007.
Cozzy 481
Postby Megaman » Tue Jun 14, 2011 8:42 pm
Yer its going to cost ya big style! :)
Postby brenmyster » Tue Jun 14, 2011 9:10 pm
also try swapping front right with back right....I had the same problem today after having BC coilovers fitted and its solved the same problem...sounds simple but it worked ....good luck ! 8)
Regards and be lucky !
Simon
#226
brenmyster
Postby Chris 280 » Tue Jun 14, 2011 9:23 pm
i used the setting kindly supplied by mega,on standard set up and works good for me ,although the garage said because they were not the stred setting for an sti they could not garantee the wear on the tires ,but wear seems fine so far on mine :)
Chris 280
Postby mikethatcher » Tue Jun 14, 2011 9:36 pm
Thanks Everyone, lots to think about :?
mikethatcher
Postby Cozzy 481 » Wed Jun 15, 2011 6:26 am
No Probs Mike ....Thats £150 please,payment in gold coins will be fine! :lol: :wink:
Bmw 320ci msport
wr1 481 (New)
Shogun (06) SORRY
Bmw 330i m sport
Cozzy 481
Postby MaverickUK82 » Wed Jun 15, 2011 8:12 am
Mines going in for a service mid July.
What do you expect the cost to be for a full geometry set up, as per Mega's settings, would cost?
Postby CAVEMAN » Wed Jun 15, 2011 8:26 am
The price should be the same regardless of setting. They just keep tweaking until they hit the numbers you want.
However, stock suspension on fixed bolts might not give you enough room to play with, so they might have to put in some adjustable camber bolts. If you have coilovers with top mounts then they can play with these also.
Postby Megaman » Wed Jun 15, 2011 9:48 am
Cozzy 481 wrote:No Probs Mike ....Thats £150 please,payment in gold coins will be fine! :lol: :wink:
Oi I paid for the settings I should get a cut! :)
:lol:
Postby CAVEMAN » Wed Jun 15, 2011 1:38 pm
Just to add to the confusion...these are my settings
Toe = 0 all round (it also stayed at 0 during spring compression testing too)
Front Camber = -2 degs 15 secs
Rear Camber = -1 degs 30 secs
A load more front camber than recommended but other than that it is the same all round. Gives a great turn in (to try get rid of the dreaded understeer) but can be a little twitchy when all you want to do is relax and cruise.
Feels great though when peddling hard.
Postby mikethatcher » Wed Jun 15, 2011 4:57 pm
Got some chocolate gold coins, will they do ? :lol2:
mikethatcher
Postby mikethatcher » Wed Jun 15, 2011 5:00 pm
G.S Auto tech Are charging £65 plus vat for a geometry set up. not sure if that includes adjustments aswell.
mikethatcher
Postby CAVEMAN » Wed Jun 15, 2011 6:22 pm
mikethatcher wrote:G.S Auto tech Are charging £65 plus vat for a geometry set up. not sure if that includes adjustments aswell.
I should imagine it will do yeah.
More than likely it won't be as per Mega's settings and defo not mine...so will require adjustment anyhow.
£65 is actually pretty reasonable, just make sure it is for the entire job, and not just per hour! 1 stuck nut, and your buggerd. Cue McTiddler's dogging comments!
Postby mikethatcher » Thu Jun 16, 2011 4:43 pm
Well i had my geometry set today, back wheels were out, but still got that bloody pulling to the right, wishbone bushes were £104 each from subaru....rip off, local garage, who knows a bit about subarus suggested Anti lift kit... Fingers Crossed.
mikethatcher
Next
