by Carl Curtis » Tue Mar 01, 2011 11:01 pm
I have a problem with my front fog lights and defi guages.
The gauges work perfectly but dont illuminate when the rest of the dash is lit.
Also the front fog lights dont operate.The illumination behind the switch doesnt come on,same as above when the rest of the dash is lit.
I have checked all the obvious fuses and they are fine.
Are the two things related.
Should the defi controller illuminate as well?
Help please.
Carl
Carl Curtis
by Bonovox » Tue Mar 01, 2011 11:05 pm
They are driving lights as opposed to fog lights and only work when on full beam I believe?
Bonovox
by Carl Curtis » Tue Mar 01, 2011 11:08 pm
Thanks for the rapid response.Will check tomorrow.
Carl Curtis
by Megaman » Tue Mar 01, 2011 11:09 pm
yup put lights on, press driving light button, then put full beam on and voilla
defis should light up as far as i know...
- Fords Number 1 Fan
by G-MAC 181 » Tue Mar 01, 2011 11:14 pm
Yes only on full beam carl, i'm puzzled why the defi illumination is not working? hope you get it sorted soon.
G-MAC 181
by G-MAC 181 » Tue Mar 01, 2011 11:16 pm
The defi controller should illuminate when you put your lights on too
G-MAC 181
by Loco2527 » Wed Mar 02, 2011 1:25 am
maybe its just a simple case of a non-connected wire? the gauges should be connected to something else that illuminates when you switch the lights on, like the dash lights. have you tried removing the defi pod to see if there are any loose or unconnected wires?
also, sorry to jump in, but i believe a little while back someone mentioned that by just swapping a few wires round on the fog/driving light switch, you could have them so they came on without using full beam.
I can't find that thread, and after fiddling round with a multimeter, I still couldnt work it out. so can anyone help?
cheers
Loco2527
by John Mc » Wed Mar 02, 2011 7:47 am
Loco2527 wrote:maybe its just a simple case of a non-connected wire? the gauges should be connected to something else that illuminates when you switch the lights on, like the dash lights. have you tried removing the defi pod to see if there are any loose or unconnected wires?
cheers
Try Autotechnica (ADAM) he is a fookin whizz at Defi's... fitted mine. He is quality!!
by Megaman » Wed Mar 02, 2011 12:52 pm
Mc Tiddler: Gay And Proud wrote:Loco2527 wrote:maybe its just a simple case of a non-connected wire? the gauges should be connected to something else that illuminates when you switch the lights on, like the dash lights. have you tried removing the defi pod to see if there are any loose or unconnected wires?
cheers
PS Why didnt you sell me your defis !!!
by John Mc » Wed Mar 02, 2011 12:58 pm
Megaman wrote:Mc Tiddler: Gay And Proud wrote:Loco2527 wrote:maybe its just a simple case of a non-connected wire? the gauges should be connected to something else that illuminates when you switch the lights on, like the dash lights. have you tried removing the defi pod to see if there are any loose or unconnected wires?
cheers
Try Autotechnica (ADAM) he is a fookin whizz at Defi's... fitted mine. He is quality!! PS Why didnt you sell me your defis !!!
You could have come round and nicked them mate
by Megaman » Wed Mar 02, 2011 5:33 pm
Mc Tiddler: Gay And Proud wrote:Megaman wrote:Mc Tiddler: Gay And Proud wrote:Loco2527 wrote:maybe its just a simple case of a non-connected wire? the gauges should be connected to something else that illuminates when you switch the lights on, like the dash lights. have you tried removing the defi pod to see if there are any loose or unconnected wires?
cheers
Ah bugger! should of thought about that... guess there is just not enough scouse in me eh?
by Carl Curtis » Wed Mar 02, 2011 6:04 pm
When the ignition first comes on the gauges do there awesome flick right around and return to normal position and also breifly illuminate at this point.
Going to get the multimeter out tonight to see if I can bottom out the problem.
Carl Curtis
by buffy » Wed Mar 02, 2011 8:19 pm
if i remember correctly i swapped the 2nd black wire in on top with the 1st black wire on bottom and i can use driving lamps with headlamps on or full beam on but not with side lights, also if you push button in and flash your full beam you should see the little blue light illimunate on switch
LBUFFIN
buffy
by Carl Curtis » Wed Mar 02, 2011 8:38 pm
Lights functioning as they should.it was just me thinking they were fog lights and not actually driving lights.Maybe should have read the manual!!!
Little blue light works aswell.
Still none the wiser with defis not illuminating.
Carl Curtis
by WR 1mposter » Thu Mar 03, 2011 10:37 pm
defi controller allow you to switch on off an dim
