Steering trouble
Steering trouble
Postby brenmyster » Mon Aug 16, 2010 7:01 pm
Hi guys
wonder if anyone can help?
Since thrashing round Brunters on Sunday my steering seems to be grinding and makes a rubbing noise whilst going round corners, noticed it a little on the last few laps, but seems to be getting worst today
Any ideas ??
Thanks
Simon
Regards and be lucky !
Simon
#226
brenmyster
Postby John Mc » Mon Aug 16, 2010 7:07 pm
not something silly like a mudflap catching when you turn to lock?
Postby brenmyster » Mon Aug 16, 2010 7:12 pm
no don't think so , can hear it grinding seems to be coming from the steering column.
Simon
#226
brenmyster
Postby John Mc » Mon Aug 16, 2010 7:13 pm
Have you checked power steering fluid levels to ensure there is enough in?
Postby brenmyster » Mon Aug 16, 2010 7:21 pm
no not yet , thought about that , but would that not just make it heavier ?
this feels like metal on metal
Simon
#226
brenmyster
Postby John Mc » Mon Aug 16, 2010 7:49 pm
Not sure mate, I'm just guessing now... I would imagine that not enough fluid would have the pump work harder which would make the steering heavier yeah... metal on metal feeling may be slight mis-alignment of rack and pinion system? Does it feel the same either lock or is it more one lock than the other?
Postby brenmyster » Mon Aug 16, 2010 8:03 pm
more right hand down
Simon
#226
brenmyster
Postby Megaman » Mon Aug 16, 2010 8:23 pm
My old ST170 had a power steering pipe leak so the fluid slowly dipped below the right level - made a horrible grinding noise when ever steering so could be that.
Does it make a difference if you are turning a small amount vs full lock?
Id guess at power steering fluid level / mudflaps catching on something / wheels hanging on by loose nuts
The experts will be able to give a better answer though :)
Postby brenmyster » Mon Aug 16, 2010 9:11 pm
yeah megaman seems to be worse turning slightly as opposed to full lock , will check fluid levels in the morning and hopefully just needs topping up or a replacement pipe/hose, worst case .
Simon
#226
brenmyster
Postby Megaman » Mon Aug 16, 2010 9:24 pm
out of interest have you tried putting the diff in manual and moving it all the way back to open mode and seeing if the issue is still there?
Postby brenmyster » Tue Aug 17, 2010 9:57 am
yeah mate , first thing I did was put the diff in open.
Checked fluid level this morning seems fine, no obvious signs of a leak
Going to a garage now to have it checked out :(
Simon
#226
brenmyster
Postby Megaman » Tue Aug 17, 2010 10:13 am
Good luck mate - might be worth not mentioning that you were ragging it on the track..
Postby brenmyster » Tue Aug 17, 2010 12:18 pm
1st opinion......near side front wheel bearing :(
Simon
#226
brenmyster
Postby Megaman » Tue Aug 17, 2010 1:39 pm
brenmyster wrote:1st opinion......near side front wheel bearing :(
Wheel bearings cant be that expensive to replace can they??
It would have been bad news if theyd have said t was the gearbox/diff that was knackered mate, be positive :)
Postby brenmyster » Tue Aug 17, 2010 2:23 pm
1 month left of the warranty, booked in tomorrow to confirm what it is :D
Simon
#226
brenmyster
Postby Crockel » Tue Aug 17, 2010 5:53 pm
If it is just the wheel bearing which needs replacing that won't be a dear fix. Parts and labour should come in around the £200 mark.
L
PS As Megaman said I would be really relieved if it is just a wheel bearing- easy and cheap compared to what could happen :wink:
Crockel
Postby Gee Wr1 » Tue Aug 17, 2010 6:33 pm
Might be wrong but i'm sure is a lot more than that to replace at a dealers, around the 400 mark for parts & labour :shock:
There was something in the leaflets you got when the extended warranty stuff came in the post & it mentioned some costs of things if they go wrong to try & get you to take the warranty. I'm sure a wheel bearing was one of the examples & 400 was the price.
Gee Wr1
Postby Crockel » Tue Aug 17, 2010 7:24 pm
Gee Wr1 wrote:Might be wrong but i'm sure is a lot more than that to replace at a dealers, around the 400 mark for parts & labour :shock:
I must admit that I never use main dealers because they are charging near on £100 a hour labour and I can't see how on earth they can justify it. I had one of my wheel bearings replaced by an independent local Subaru specialist recently and using Subaru (not patent) parts it was £200 all in.
Replacing wheel bearings should be straightforward for any half decent mechanic so if they ask for £400 definitely look elsewhere!
L
Crockel
Postby Megaman » Wed Aug 18, 2010 12:36 pm
Yer my local stealership charges 90 per hour plus vat for labour - total rip off
Postby John Mc » Wed Aug 18, 2010 4:20 pm
Megaman wrote:Yer my local stealership charges 90 per hour plus vat for labour - total rip off
But you are paying for the nice comfy chairs, heated building, coffee machine, fit resceptionists...
Anyone seen any of these? :?
Postby Crockel » Wed Aug 18, 2010 6:19 pm
brenmyster wrote:1 month left of the warranty, booked in tomorrow to confirm what it is :D
Any news?
L
Crockel
Postby brenmyster » Wed Aug 18, 2010 6:44 pm
had to re appt , due to work , booked in tomoz now Thursday.....will let you know :D
Simon
#226
brenmyster
Postby Azyman » Thu Aug 19, 2010 1:19 pm
My money is on a wheel bearing mine made a horrible noise when my rear wheel bearing went thought it was the diff :)
Regs
Geoff
Azyman
Postby Megaman » Thu Aug 19, 2010 2:51 pm
Dont forget the prompt service, where Megaman takes you out for an hour in the Focus ST and drops you off to find its still not ready...
Wonder how they define "Shouldnt take long" :)
Postby brenmyster » Fri Aug 20, 2010 9:25 am
It turned out to be a heat shield from one of the downpipes, the weld had broke top and bottom and as you turned the wheel it was rubbing on the main steering rod......as I had a big fat turbo and down pipe fitted recently the movement on install may have disturbed an already weak weld....seems ok now thou .....although the garage were not to happy to do it under warranty as I voided it after having new turbo and exhaust and engine re-map....but they begrudging did it in the end. :D
Simon
#226
brenmyster
Postby Crockel » Fri Aug 20, 2010 9:29 am
Great result-you can't beat a free repair!
L
Crockel
Postby Megaman » Fri Aug 20, 2010 11:42 am
glad to hear its sorted out mate :)
