Think these are fooked lol
Postby Foley » Tue Jun 22, 2010 1:49 pm
Had new brakes sitting in my garage for a while now just couldn't be fooked fitting them,
But lately the brakes were getting worse, The brakes were red stuff and there shite :lol:
Here was the red stuff pads that came off today :shock:
These were on the inside of the brake calipers so could not see that they were that bad, The out side pads still had a lot of life left on them,
Postby The Swede » Tue Jun 22, 2010 3:43 pm
Be happy. Mine looked only 'worn' when they were on the car and when they took them off, they fell apart. :?
For some reason the mechanic did not want a lift back home with me :lol:
Postby CAVEMAN » Tue Jun 22, 2010 8:44 pm
what you playing at...plenty of meat left on them!! :shock:
lucky you got away without scoring the discs too.
Postby Foley » Wed Jun 23, 2010 7:31 am
CAVEMAN wrote:what you playing at...plenty of meat left on them!! :shock:
Yer i got them just in time, Any longer and the discs would have been fooked aswell,
Any reason why the inside pads wore twice as fast as the outside pad?
Postby asperformance » Wed Jun 23, 2010 7:41 am
i would check that the pistons are all free to move and also that both sides of the caliper are bled correctly (you'd be amazed how many peeps ignore the 2nd bleed nipple)
Postby Foley » Wed Jun 23, 2010 10:33 am
asperformance wrote:i would check that the pistons are all free to move and also that both sides of the caliper are bled correctly (you'd be amazed how many peeps ignore the 2nd bleed nipple)
All the pistons were fine to move, Will check the other bleed nipple,
Cheers j
