SIDE LIGHT BULBSAny idea how to replace front side light bulbs?
1. Take off front grill, there about 5/6 plastic clips, but be careful very fragile and remove grill !
2. There are 5/6 plastic poppers on the bumper , screwdriver under the centre section and prise up and remove, then pull the bumper away slightly from the car ! 3. A white clip/bracket attach to the headlight, (again fragile) on with a 10mm bolt remove plus the 2 bolts on the top of the headlight assembly 4. Your headlight is now held on with 2 clips on the innerwing so again gently prise the headlight away from the car, just enough to get you hand in and twist the side light bulb out and replace ! 5. Follow in reverse order to put together again ! 6. Take it to a dealer and let them do it ! its a 10 minutes job for someone who knows what ther doing and a couple of hours if they dont ! Plus you may break the grill clips and the white headlight bracket ! 2007 BMW M5
Its tough especially if your sidelights melt because they are always on like mine did, so buy a couple of pacs of the same bulb, my advise
98 DC2 Integra type R
00 Audi TT 180 Coupe 03 DC5 Integra typeR 02 Alfa spider V6 01 Honda s2000 03 Audi TT 225 roadster 02 Porsche Boxster S 06 porsche Cayman 04 Subaru Impreza STi WR1 Now: 07 BMW Z4M
