Project "666"
Project "666"
Postby rocko » Sun May 16, 2010 3:24 pm
Hi, Guys i know how you much all love modding projects, I felt a bit left out .. so i wanted to join the stroker club .. So after long research .. and pickin ppls brains ...I decided i need a big help in hand to make tis happen ..
After a few weeks of long research i decided to go with
Advanced Automotive's & CP Auto's Team
There knowledge in subaru tunning is immense
From summer time last year till now they have kept me in the picture from day one ... On helping me build a build plan for my requirements ..
so this is were ime at ..
I have a CDB EJ20 cases with the following:-
Spec C heads and cams
Spec C inlet manifold
Rcm fuel rails
Rear thrust conversion
14mm head stud conversion
Advanced Automotive's 2.1 competition stroker kit using their Manley steel rods with the nitrided 79mm crank and Mahle 92.5 2618 competition pistons
Perfect Circle piston rings
ACL competition bearings with modified centre bearing
12mm modified oil pump
Cosworth baffle plate
New sump
New Gen oil cooler modine
New timing belt kit
New water pump
Group N engine mounts
Supertech valves
Lots of engineering and secret stuff
8.4:1 CR
And a Billet GT30R twisted turbo kit etc for the desired 500bhp plus.
Billet wheel is 33% lighter which produce more bhp than its older one
Thanks for looking ppl .. Ill keep you up to date with pictures and Spec as they get on ..
rocko
Postby CAVEMAN » Sun May 16, 2010 4:07 pm
Wow...I would to be doing something like this, and your spec sounds very similar to my config too - but I am not into that much detail yet. The 2.1 stroker kit is defo the way to go.
Only difference is that I hope to build my own block - just for a laugh and see what it involves...can't be that hard can it? Just get the machine work done before hand.
I presume FMIC and aftermarket ecu are on the list too....what injectors you going for?
keep it up to date matey....got my eye on this project for sure...
should be stunning afterwards! good luck.
Postby rocko » Sun May 16, 2010 4:11 pm
CAVEMAN wrote:Wow...I would to be doing something like this, and your spec sounds very similar to my config too - but I am not into that much detail yet. The 2.1 stroker kit is defo the way to go.
I already have a APS steath Front mount .. Just got to customize the hard pipes ..
And i run a Simtek , And for the injectors .. i got rcm 800 but goin to change for 1000cc ones
rocko
Postby Thomo no 11 » Sun May 16, 2010 4:33 pm
rocko its taken a while mate but bloody hell i bet its worth it!
sounds sweet bud get some vids uploaded :woohoo:
Thomo no 11
Postby rob500 » Sun May 16, 2010 5:30 pm
this is going to be a right "beast" 8) look forward to the results from the "billet" turbo :wink: im assuming dave rowe will be mapping it?
rob500
Postby rocko » Sun May 16, 2010 5:54 pm
rob500 wrote:this is going to be a right "beast" 8) look forward to the results from the "billet" turbo :wink: im assuming dave rowe will be mapping it?
cheers Rob . . Yeh dave will be mapping .. Aint heard of him for a while i guess his busy man ..
rocko
Postby rob500 » Sun May 16, 2010 6:02 pm
great thread :D keep us updated :thumb:
rob500
Postby WR 1mposter » Sun May 16, 2010 6:18 pm
sweet dude :lol:
Re: Project 500 + WR1
Postby MY498 » Sun May 16, 2010 7:11 pm
rocko wrote:Hi, Guys i know how you much all love modding projects, I felt a bit left out .. so i wanted to join the stroker club .. So after long research .. and pickin ppls brains ...I decided i need a big help in hand to make tis happen ..
Rcm fuel rails
New sump
New timing belt kit
New water pump
Supertech valves
8.4:1 CR
Rocko, what kind of approx cost is involved in getting to this satge :shock:
MY498
Postby rocko » Sun May 16, 2010 7:21 pm
Well if your willing to ring around to get decent second hand cases and heads .. you can shave ££££
example .. decent Spec c heads inc cams £650
New from japan with out cams just bare heads £1700 ..
the stroker kits can be found on some sites for around £1200/ £1500
supply only .. which includes pistons,rods,crank,ACL bearings, seal kit
You can get a drive in drive out option for around 5k .. plus your twisted kit and then turbo ...
My budget went out the window ages ago lol ...
rocko
Postby Foley » Sun May 16, 2010 7:30 pm
Fook me rocko you don't do things by half :shock:
I think you want to be the WR1 daddy :lol:
Can't wait to see this when it's finished,
Postby rocko » Sun May 16, 2010 7:36 pm
Foley wrote:Fook me rocko you don't do things by half :shock:
Lol Rosy B will Always be the daddy .. in my eye's ... Fair play to them as we all look up to them as a dream ... I was chatting to them sat @ jap fest ... they are so gennuine nice couple ... And for fook sake the both colleting there pension and blasting around in a awesome car lol ..
I'll know right this min his out there cleaning his spokes .and getting another coat off werksatt lol
rocko
Postby Foley » Sun May 16, 2010 7:43 pm
Yer thats is some machine ROSY B 8) Great people rosy and chris,
What spec was p060064h wr1? That was crazy lol
Postby CAVEMAN » Mon May 17, 2010 6:47 am
in my book you are doing it the right way...I am not sure I would trust or even want a second hand block in my build.
For sure it has got to be treated carefully to start with until it has gone through enough heat cycles to make sure everything is OK.
But if you are spending that kind of cash in other areas too - an extra 2-3k to make sure it is safe is fine with me.
Reckon 8-10k would see you get somewhere close or at least i hope so!!....more if you then start putting fancy bits on like aeroquip fixings and hoses.
Truely, truely jealous mate!!! :twisted: but the best of luck to you and I hope you get what you wanted at the end of it...enjoy the journey, because for me that would be 70% of the kicks just doing the build.
Postby Chris B » Mon May 17, 2010 11:30 am
They are a lovely couple and the spokes have been cleaned werstatt next,ready for JTS at Silverstone this sunday.
Chris B
Postby Foley » Tue May 18, 2010 7:39 am
Love that turbo mate :shock: , Thats going to be mental when that boost kicks in, My little one is peppa pig daft aswell lol
Postby WR1 Bro » Tue May 18, 2010 7:58 am
Looking forward to Brunters.....
Hope it all goes well mate. Very jealous indeed!
Postby danr55 » Tue May 18, 2010 9:55 pm
Can't wait for a ride at Brunters too 8)
Postby rocko » Wed May 19, 2010 8:51 pm
Right guys .. Just an up date on were the guys are at the min .. Drop my car off last week .. Which Spence wasted no time and getting stuck in ...
As you can see The old Motor is out
Also nick at Advance has been preping my heads to machine and fit new supertech vavles, Also he Recons buy the end of the week my motor will be built ..
Then i guess it will get sent too spence to re fit new motor ...
Cheers Guys loads more to come ...!!! SOON
rocko
Postby Foley » Wed May 19, 2010 9:03 pm
Am so jelous mate :wink: Bet your getting excited bout getting the car back, 1000 miles with no boost :lol:
Postby rocko » Wed May 19, 2010 9:08 pm
yeh i am but enjoyin all this at the mo never had out done like this before .. Its all so intresting ...
And the guys keeping me posted every step of the way ..
rocko
Postby WR1 Bro » Wed May 19, 2010 9:28 pm
Sex, pure sex
Postby Megaman » Wed May 19, 2010 10:57 pm
Pure Quality
:bow: :bow:
Postby Chris B » Thu May 20, 2010 1:39 am
Rosy B is getting a friend,go for it Rocko.
Chris B
Postby CAVEMAN » Thu May 20, 2010 5:29 am
looks really well done, and I bet at a fraction of the cost of 'the other' garage.
very professional....fantastic.
Postby Chris B » Thu May 20, 2010 1:43 pm
Running in can be fun we found, getting to know the car,the different engine sound,it will still be quick off boost,the turbo sound,the waste-gate sound,its window down and stereo off
Chris B
Postby stijoy » Fri May 21, 2010 4:34 pm
god not another load of pics showing engine bits again :rofl:
stijoy
Postby rocko » Sun May 30, 2010 2:28 pm
A little up date guys ...
Engine is fully built and has left Advanced Automotive and Its landed at CPA with spence And Nick to start fitting from tues on wards ...
I also receveed my Garrett GT30 R Billet Which I've now sent to be Ceramic coated along with My Rotated Downpipe
But still loads to do in the engine bay and custom made parts and some trick parts ...
rocko
Postby marky mark » Sun May 30, 2010 5:03 pm
I don't know much about advanced automotive but what i can see from the pics that you have probably made a decent choice.
They are using plenty of molybdenum disulphide assembly grease on the head bolts and cams which is a good sign. A lot of so called engine builders might just put a squirt of oil in there which is not as good on initial start up as moly, or a moly/oil mix.
Postby rocko » Sun May 30, 2010 6:11 pm
marky mark wrote:I don't know much about advanced automotive but what i can see from the pics that you have probably made a decent choice.
trust me marky ... I done sh## loads of home work on choosing my builder ... They come highly recomened from ... The bset subaru tuner's
Also they have done lots of stroker kits too ... So i knows its in good hands ... there are well busy ...
pasty's is next once mines see day light again ... cheers for looking
Rocko
rocko
Next
