Atmospheric Dump Valve.
Postby MaverickUK82 » Thu Aug 27, 2009 9:26 am
Is it true that an atmospheric dump valve, as opposed to the WR1's recirculating dump valve is increase performance slightly:
"The Impreza is already fitted with a recirculating dump valve, however this can be removed and a atmospheric dump valve installed to give a loud " woosh" sound when changing gear and a slight improvement in turbo lag." Scoobyworld.co.uk
Postby John Mc » Thu Aug 27, 2009 9:57 am
I think this was discussed on here before and there was no performance improvement over the recirculating iirc...?! Just a preference over the noise!!
Postby Megaman » Thu Aug 27, 2009 10:03 am
I know on other cars that dump valves actually slow the car down marginly but I dont know about the scoobs... Probably not much in it either way...
Postby CAVEMAN » Thu Aug 27, 2009 10:06 am
come on think about it for a little bit...
why is it there, what does it do?
So why waste air by pumping it back into the atmosphere, when you can put it straight back into the intake system?
Keep it as it is...if you want noise at a gear change then run with anti-lag!
Postby MaverickUK82 » Thu Aug 27, 2009 10:08 am
CAVEMAN wrote:Keep it as it is...if you want noise at a gear change then run with anti-lag!
Postby CAVEMAN » Thu Aug 27, 2009 12:37 pm
pop....bang??? happens when you lift off the throttle i.e. gear change...unless you flat shift
Postby jimmy » Thu Aug 27, 2009 1:07 pm
it doesnt give any power but maintains boost
ver9 grey blobeye sti
jimmy
Postby MaverickUK82 » Thu Aug 27, 2009 2:27 pm
"Run with anti-lag"?
"Flat shift"?
lol - i'm new to all this.
Postby jimmy » Thu Aug 27, 2009 2:44 pm
anti-lag breaks your turbo and flat foot breaks your clutch lol :lol:
jimmy
Postby CAVEMAN » Fri Aug 28, 2009 7:49 am
anti-lag is just a simple way to keep the turbo spooled up when your not on the gas.
When you lift off the car bascially retards the ignition but still dumps fuel into your cylinders, so it passes straight through and actually burns when it hits your hot manifold...so explodes (hence the pop n bang and flames) and the hot gases hit the turbo keeping it spinning.
Now when you floor it again (say out of a hairpin) the turbo is already up to speed and gives you boostage - hence the name anti-lag. Using a tad of left foot braking also helps to keep everything on boost too.
Flat shifting in most after market ecu's, with manual gearboxes is just a fuel cut...just change gear as normal but you can keep your foot to the boards and the fuel cut will happen preventing blowing your engine. But as you are not lifting off then you don't get the anti-lag type explosions....
Postby spraggol » Sun Jan 03, 2010 10:42 pm
jimmy wrote:anti-lag breaks your turbo and flat foot breaks your clutch lol :lol:
Well said :)
Dump valves may sound cool but think of all that wasted air. Stick with the original setup and be happy with the amazing sound of the flat 4!
WR1 no. 427
spraggol
Postby CAVEMAN » Mon Jan 04, 2010 2:45 pm
not if you have the right parts to start with...
Postby dynamix » Mon Jan 04, 2010 7:04 pm
CAVEMAN wrote:Flat shifting in most after market ecu's, with manual gearboxes is just a fuel cut...just change gear as normal but you can keep your foot to the boards and the fuel cut will happen preventing blowing your engine. But as you are not lifting off then you don't get the anti-lag type explosions....
... unless you run anti lag and flat shifting ;) cough cough bang bang BANG
Duncan : www.racedynamix.com
email: duncan@racedynamix.com
tel: 07540 185754
dynamix
Users browsing this forum: No registered users and 30 guests
