Knocking noise
Knocking noise
Postby Foley » Fri Nov 06, 2009 6:13 pm
Got a knocking noise from the back of the car every time i pull away,
Can it be the back shocks?
There's no knocking noise when i go over bumps just when pulling away,
It's not loud but it's fooking annoying me :evil: Any idears?
Cheers j
Postby Bonovox » Fri Nov 06, 2009 6:15 pm
Foleys shockers RIP :lol:
Bonovox
Postby Foley » Fri Nov 06, 2009 6:22 pm
:cry: Car just had a service today now more money for shocks :(
Postby Bonovox » Fri Nov 06, 2009 6:34 pm
Foley wrote::cry: Car just had a service today now more money for shocks :(
Did they not check them when you had it serviced? I was lucky i got 3 replaced under waranty, It might not be your shockers but lets face it it's a weakness with them and there's a good chance that will be your problem. A bit o a bugger I imagine it wont be cheap?
Bonovox
Postby Foley » Fri Nov 06, 2009 7:17 pm
Na they never said anything to me about the shocks :shock:
Need to go and price a set of shocks now at subaru :evil:
Think i'll just store the wr1 away and for winter and get everything
needing done after xmas, Or the kids wont get anything fae santa claus lol
Postby Autotecnica » Fri Nov 06, 2009 8:10 pm
Get some coil overs foley no point wasting money on subaru shocks they'll only go again in another two years.
Autotecnica
Postby Foley » Fri Nov 06, 2009 8:42 pm
Autotecnica wrote:Get some coil overs foley no point wasting money on subaru shocks they'll only go again in another two years.
Cheers sounds a better idear to get coil overs than put subaru's pish shocks back on,
How can i check to make sure it's the shocks?
Postby John Mc » Fri Nov 06, 2009 8:42 pm
Aye, what Adam says :lol: I paid £300 a side for mine with 3 year/60k mile warranty.... once they go I'll be changing for something else!!
Exe-tc's hmmmmmm
See you Monday Adam.
Postby Autotecnica » Sat Nov 07, 2009 9:36 am
the noise you're describing can only be rear shocks, if you jack the rear of the car up and pull up the shock boot the inner chrome part will look tarnished in places due to the shock sticking.
push down on the rear of the car with the boot open so you don't damage the panel and if the shocks are totally gone the car won't move.
hope that helps.
Autotecnica
Postby Micktype WR1 » Sat Nov 07, 2009 6:58 pm
Expose the chrome part and get some lubrication on there. IT WILL stop that lumpy feeling you feel when you pull off. Mines been like it for nearly 2 yrs and I lubricate them every 3 months....works a treat !
Micktype WR1
Postby Foley » Sat Nov 07, 2009 7:01 pm
Micktype WR1 wrote:Expose the chrome part and get some lubrication on there. IT WILL stop that lumpy feeling you feel when you pull off. Mines been like it for nearly 2 yrs and I lubricate them every 3 months....works a treat !
Do you use oil or grease to lub them up?
Should it knock when am going up through the gears?
Cheers j
Postby chiroman » Sun Nov 08, 2009 5:30 pm
Check rear exhaust mount bracket not fouling exhaust and clunking as let clutch in.
chiroman
Postby Megaman » Sun Nov 08, 2009 7:15 pm
our local subaru dealer tests for knackered shocks by pushing down on the boot whilst the car is stationary if that helps.
btw foley when did you get the car back and apart from the shocks is it all ok again now mate?
Postby Foley » Sun Nov 08, 2009 7:50 pm
Megaman wrote:our local subaru dealer tests for knackered shocks by pushing down on the boot whilst the car is stationary if that helps.
Got the car back mate all is fine apart fae the back shocks,
Will try and push down the boot tomorrow,
Cheers j
Postby Megaman » Sun Nov 08, 2009 8:19 pm
glad to hear it mate
are the coilovers still fitted inverted?
if so wont they suffer the same issue as the standard ones...
as a guide ive had my rear shockers changed by subaru 6months after getting the car then again within another 12 months under warranty.
if i spent a bomb on coilovers which all seem to only come with 12months warranty unlike the subaru 3yr warranty id be gutted if they started to knock too due to the same design fault 18months down the line.
Postby WR 1mposter » Mon Nov 09, 2009 12:09 am
Is a knocking nose caused by the nodding dog being to close to the rear screen :lol: :lol: :lol:
Postby Megaman » Mon Nov 09, 2009 12:52 pm
WR 1mpostor (aka number 1 moderator) wrote:Is a knocking nose caused by the nodding dog being to close to the rear screen :lol: :lol: :lol:
It could be Foleys nodding churchill dog on his parcel shelf... :lol:
Postby The Swede » Mon Nov 09, 2009 1:33 pm
The shocks are by definition not 'broken' because they knock.
When I had the issue on my STi, I had a good dig around at the cause. Turns out that the seals are giving up after a while. That means dirt can enter the shockabsorber AND you get some play (fraction of a millimeter).
We couldn't reproduce the noise, unless we were driving and when they took the shocks off, the mechanic showed that, by moving the shaft sideways, you got a bit of a clonk and a very small amount of play.
Risk is that you replace them with the same shocks.
Postby CAVEMAN » Mon Nov 09, 2009 3:38 pm
oh man, this is just begging for somebody to try that re-greasing trick...come on do it already!!
Users browsing this forum: No registered users and 41 guests
