Users browsing this forum: No registered users and 65 guests
Turbo timers..........yes or no?????My mate had a turbo timer on his rb5 r they all there kopt out 2b? & if so & they do look after ur pride & joy y don't they EVA come as standard?
I will attempt to translate: Are turbo timers all what they are made out to be? If so, why aren't they standard? My attempt to answer: I believe so, as they allow the turbo to spin down and before the engine stops thus prevent metal to metal grinding. So affectively prolonging the live of the turbo. Reason not standard is probably due to safety and insurance purpose of having a car running unattended. However, if you just drive easy in the last few miles before turning the engine off, then a turbo timer isn't necessary.
Well said Ferret 2007 BMW M5
Sorry but i think they are a total gimmick & waste of money!
You should be allowing the car to cool before turning of anyway, so why spend £100 for a little display to tell you to do it? The last few miles of your journey take it easy & try & stay of boost then give it some time when you stop. If you've been ragging it then stop give it 3-4 mins before switching of, thats all a turbo timer will tell you. Stick the stereo on listen to some music & watch the track timer on the stereo to see how long its been cooling. They have to work with your alarm if you want to lock it while its still cooling & think there is some probs doing so with the alarm fitted as standard on scoobs. Its just a novelty that the car can turn itself of while your out of it. Also some insurance companies don't like them & will void your policy. Other cheaper option is buy a 3 minute egg timer, when you stop turn it over on the dash then you can watch the pretty coloured sand trickling down into the bottom as it counts down Beats watching a digital display counting down Also as well as timing the cooling of your car you will also leave the car feeling relaxed & chilled out from watching the pretty coloured sand
You used to be SO gentle Mr Gee?
What about when filling with fuel, i allow my car to tick over during filling, but heaps of people must switch theres of to fill up.
What would happen if you never let cool down 98 DC2 Integra type R
00 Audi TT 180 Coupe 03 DC5 Integra typeR 02 Alfa spider V6 01 Honda s2000 03 Audi TT 225 roadster 02 Porsche Boxster S 06 porsche Cayman 04 Subaru Impreza STi WR1 Now: 07 BMW Z4M
The reason for letting the turbo cool is that the turbo has a feed of oil running through it, when the turbo is running on boost the exhaust side runs very hot, if you allow the turbo to cool when hot it does so with a flow of oil going through it, if you just turn of there is no flow of oil running through it & the oil that is in it just cooks due to the high heat from the hot turbo & leaves deposits that end up blocking up the turbo bearings & oil lines.
Who is onlineUsers browsing this forum: No registered users and 65 guests |
