Performance Friction quote for fronts, any good?My local Subaru approved service centre quoted me the following for Performance Friction on the front:
Disc £248.50 each Pads £122.91 for the pair Labour £89.10 Total £815 including VAT Good price? Based on Zen Performance prices, seems good to me: http://www.zenperformance.co.uk/p/product/b Should I also consider 5.1 brake fluid and braided hoses??? All feedback appreciated.
1. Pointless having upgraded brakes when your hoses will still flex and the liquid will boil any time you push a bit.
So first fit the hoses and the put proper liquid in. That will get more out of your brakes. 2. I have been running the PF's on the Evo. Despite being "reasonably heavy" on brakes, they did an outstanding job. I would recommend them any time.
That price is ok. Igot mine from Zen & got a deal on buying front discs, front pads, rear pads, braided hoses & 5.1 fluid. There's not much between the prices as most of the discount i got came of the postage(which is always more expensive to the highlands)
Fitted them myself apart from the hoses which i got fitted by the dealers when it got serviced. Fitting discs & pads is quite easy actually in a couple of hours.
Do you have children? And does your wife allow them with you in the car??
Nope no kids just a dog
Why you think i'm not capable of fitting a set of discs & pads myself? Come on it's not that hard or complicated to do if you have half a brain & are handy with a spanner, just look at the kinda people who fit brakes at the like of kwick fit if the can do it with their lack of brain cells & masses of spots even you could do it Swede But then again if i mind you had problems fitting or removing mud flaps so maybe not in your case Oh & it takes a bit of muscle to remove the caliper bolts so you might fail on that to Are you just all theory & knowledge about cars but not practical?
Quality Gee ! Sweede does need some mister muscle 2007 BMW M5
You're practical, I'm theory, you have a dog, I don't and you have no kids and I do... That's 3 pieces of good news in one evening ! As for cars, I keep myself to driving them and letting people who want to make a living out of it to work on them.
Thanks, I think I will be getting Performance Friction plus the 5.1 brake fluid and braided hoses
good decision and it is easy to fit them Duncan : www.racedynamix.com
UPDATE
Got additional quote for Goodridge Stainless Steel Brake Lines and Dot 5.1 silicone brake fluid for £120, bring the total to £953 included VAT. Still good deal? That's for: Performance Friction 2 piece floating discs x2 Performance Friction Carbon Metallic Pads I've noticed on Performance Friction website they have a Z rated pads, which one should I consider the Carbon Metallic I've already been quoted for or these Z rated pads? Your advice is much appreciated.
Definitely worth it mate...I can't believe just how much difference they made.
Got the SS Goodridge hoses too, but instead of the 5.1 fluid I got the 551 racing fluid. see here...http://www.apracing.com/info/info.asp?s ... Details_48 get it done!!
I will be next week
The place I'm getting it done, only has 5.1 which they use on all the Subarus, I'll asked about the 551 but I got feeling they will say they don't stock. Know anything about the difference between PF Carbon Metallic pads and the Z rated pads, which ones do you have?
To be honest I am not 100% sure, but I think they are the Z-Rated ones.
They are my first set, so have no comparison to the normal Ceramic ones. But from the PF website, it says these are near silent and don't give off as much dust. Which mine definatley do not do! They do squeal a bit once warmed up, but I like that to be honest...means you've been giving it the beans! All rally cars go into the time check and pull into service with squeaky brakes!!
My 1 is at Subaru today getting front brakes done :
Performance Friction 2 piece floating discs x2 Performance Friction Carbon Metallic Pads Goodridge Stainless Steel Brake Lines Dot 5.1 silicone brake fluid Looking forward to getting her back this evening
Should have taken them to Adam at Autotechnica... I'm sure he'd be more reasonable on the fitting charges than the stealer... You got some serious braking planned soon?? [Just incase this gets lost in translation, I am not slandering you, I know people can be sensitive to these harsh words.]
What is the difference between this and Dot 5.1? As far as I can read, you can't use Dot 5.1 with Mineral Oil systems.... it doesn't say anything on the 551 about this other than compatible with Magnesium systems... [Just incase this gets lost in translation, I am not slandering you, I know people can be sensitive to these harsh words.]
I think I got quoted reasonable price for labour and it's just round the corner from me. No serious braking plans, just my front were getting worn and need replacing soon ish. Rather then replacing with same Brembo, I went for PF as recommended by many members on this site and got them sooner rather then later
My 1 now has PF disc and pads. Subaru said the brakes will be "soft", allow them to bed in, however I didn't relise how "soft", braking is quite poor at moment, is this normal???
Also since having my brakes done, my geo out again, is this expected???
did they bleed them properly?
Mine were great right from the start! They are a little squeaky sometimes, but other than that the pedal feel is great and now they are bedded in they are even better. If you give them 50 miles or so of normal driving then really stand of them hard at serious speed...then another 50 miles, then another stand. Beds them in nicely
I would assume so, as they did do a brake fluid change. I've only done 50 miles or so, will give it at least 300 miles before I step on them unless it's an emergency I'm hoping as they bed in, they will get better.
Only done 300 miles with the new brakes, starting to brake quite well now Still not fully tested under heavy braking, will cover some more miles before trying that.
good news, glad to hear they are OK.
I would stand on them soon for sure. Won't do any damage at all, you might hear a strange sound if you do, but this is just the holes in the disks whirring through the pads. Also, after major breaking when you sit a lights and stuff always use the handbrake. If you keep your foot on the brake to hold the car stationary, then all the residual heat in your pads get transferred to a small spot on the disc and could possibly warp it. It is always good practice to do this anyways, but especially after heavy use.
Who is onlineUsers browsing this forum: No registered users and 5 guests |
