Im going to look at a wr1 tonight and the previous owner reported temperatures of 120 degree's is this normal ?
Thanks
oil temperature, what should it beIm going to look at a wr1 tonight and the previous owner reported temperatures of 120 degree's is this normal ?
Thanks
hi
are you talking about oil or water temperature? i have an oil temp gauge and driving normally is about 80 degrees but if you give it some beens it goes up to approx 100 but on my water temp its just below half way or there abouts,hope this helps! gary. ![]() ![]()
oil temp should certainly not be 120 on normal driving. Perhaps on track conditions, also depends on the type of oil it's using. assuming this car has an oil gauge?
120c = seized
![]() ![]() Previously: Everything With 4 Wheels over 300bhp
120c for any car is pretty flipping hot - possibly guage scale is out or they are using the wrong oil.
a guy I know with an Evo said his runs at around 135 which I suggested sounded very high, he said it was fine
Yeh I think 120 is max running temp Dan, If I was doing track days I think id be sticking in a bigger oil cooler for sure.
Mine creeps up to around 90/95 if I'm sat in traffic but comes down to 80 when I get moving again - think the warning light is set to come on at around 115/120...
Is there a lower threshold thermostat available so it kicks in at a lower temp? Always put these on my other cars just to be safe.
Re: oil temperature, what should it be
I'd take your shorts and a t-shirt if it that hot where he lives ![]() ![]()
My defi run at 90/95 on normal and 100/115 for track use, not that the car is capable of being used on the track
![]() 2007 BMW M5
Thermostat ? are you talking about the oil or the water here ? The standard car only has a standard oil cooler, to improve oil cooling you can fit a mocal oil cooler with more rows on it. Previously: Everything With 4 Wheels over 300bhp
