Time Attack 2008 STi - new dyno figures !!Okay now that the TA entry is in I can progress at full speed to get this up and running before the first event at Donnington. 91 days to go !!
I have decided to bite the bullet and up the ante for this year The to do list is pretty huge but to summarise: Power: - Engine (being built) - Turbo (ordered) - FMIC (ordered) - GT Spec Gen II Headers (ordered) - Baffled Sump (to be decided on) - Mapping - Clutch (ordered) Handling: - Whiteline camber bolts (ordered) - Track Focused Alignment - change wheel bearings Brakes: - Fluid change - Fit cold air ducting - General checkover Interior: - Seats (ordered) - Rails (ordered) - Firewall & fittings (ordered) Tyres: - Toyo R888 to be ordered Exterior: - Aero work Power targets are around 450+ bhp & 500 lb/ft so it should be quick enough to compete if I am Last edited by dynamix on Sun Oct 19, 2008 5:22 pm, edited 14 times in total.
Duncan : www.racedynamix.com
must be costing a few quid, looks forward to seeing the finished result!! What seats are you going for out of interest?
Yes
Seats are Corbeau Sprints Duncan : www.racedynamix.com
Top man
There are some really nice cars being/been built on this forum Hurry up and get it done - Passenger rides? Get the small seats so not fatties can fit Donk Crash bang wollop!!
Re: Project STi - Time Attack 2008 ... more power scotty !!
Drifting competition ?
Re: Project STi - Time Attack 2008 ... more power scotty !!Engine (being built) Turbo (ordered) FMIC (ordered) Clutch (ordered)
Which make/parts will you be using ? 2007 BMW M5
The clue is in the thread title www.timeattack.co.uk Duncan : www.racedynamix.com
Engine is a 2.5 EJ257 Semi Closed Deck Block with top hat liners to enable it to withstand well over 500 lb/ft torque. Pistons are Wiseco forged Rods are Pauter Crank is custom STI forged ARC race shells ARP head studs Heads will be machined to accept O rings All this will give the engine the ability to run 650 ish bhp should I want to at a future date but for now it will be limited by the size of the turbo to keep it driveable on the road as well as track. Turbo - FP Green with 8cm Turbine housing and 3 inch inlet Cooled through an APS DR725 front mount. Clutch isnt finally decided but will be shortly. Duncan : www.racedynamix.com
oh yeah - forgot about them
Strewth! What a list! Sounds like a serious financial investment, Duncan. Good luck with the build and do give us a write-up as you go along and also a test drive briefing?
It will be when it happens - just waiting for a firm date that it goes in for a new heart then I can start planning all the little bits and work on a running in map for it.
Did you rob abank or something??? Thought you said your pockets weren't that deep on your previous thread, will we be seeing you be on crimewatch Lol
Sounds like it'll be a stormer when finished Will look forward to seeing you at Knockhill this year with it assuming TA will be coming north again this year.
The dates for Time Attack are:
R1 April 5/6th Donington Park Circuit – International Styling and Tuning Show R2 May 17/18th Knockhill Circuit, Scotland R3 June 1st Silverstone Circuit – Japanese Tuning Show R4 July 5th Oulton Park Circuit R5 August 10th Brands Hatch Circuit – AUTOTUNER Show R6 October 12th Snetterton Circuit I have entered the whole series this year so if any of you guys want to come along and watch .... No - not robbed a bank, but I am being supported by Area52AutoSport ( www.area52autosport.com ) for the series this year and getting a lot of help from them in the engine, tuning and fitment side of things to help me be as competitive as possible. Area 52 are currently ScoobyMania but are in the process of rebranding as part of a widening out of their market beyond just subaru tuning where they are the longest established tuner in the UK and possibly europe, to cover Evo's, Nobles and other marques. I am thankful of their support in this high profile series and look forward to a great season ahead and as usual I will be documenting as much of it as possible. (good and bad) Duncan : www.racedynamix.com
First pics of the baby engine being born :)well a sample picture of what the internals look like anyway
The crank I presume you mean?
The STi one is forged as std but the one that is going in my engine is custom drilled to allow for better oil distribution. Duncan : www.racedynamix.com
Almost every 'track/race' car has an extending front splitter to counteract the inherant lift properties generated by the shape of the vehicle. Those that dont feature a venturi effect front to speed the airflow underneath. There is a reason for this
In real life testing, admittedly not by me, but on my exact model of car, the following was recorded: Red arrows represent lift/downforce at air flow of 144km/h Blue arrows represent lift/downforce at air flow of 200km/h This shows the downforce on the car at speed compared to an evo. It demonstrates that the car is engineered to go light at the front with speed and thus create more understeer as this is acknowledged as being the safest for normal use. It also shows that the rear spoiler/roof spoiler/improved under floor panelling and diffuser on the 2006 STi are actually functional items. The front splitter design will utilise well known (apparently ) Bernoulli equation: To create a positive pressure at the front and, through the fitting of a protruding lip splitter, downwards on the lip. The ideal from research seems to be a protrusion of 3 inches to create a sizeable amount of downforce. I will be creating a degree of adjustability within the mounting points so that I can vary the amount of lip and therefore the amount of downforce so as not to upset the balance of the car. Hopefully this can be tuned at each circuit to suit the characteristics on the tracks. Coupling this with a lower front of the car (it will be dropped by about 12mm) and a flat(er) undertray to speed the air under the engine bay (pressure drops with velocity), this will create additional suction onto the road. The ideal will be to take Craners flat The material/construction is currently open for debate but favourites at the moment are marine grade plywood or a composite ally/abs plate Duncan : www.racedynamix.com
Carbon Fibre Rear BulkheadNow that the carbon sheeting has arrived, time to make a bulkhead behind the rear seats.
Although this wont be fully fire tight as there are numerous other holes fittings that would need to be removed such as the rear selt mechanisms (what are staying for the moment) it will help reduce some of the noise of having an open boot at events and besides which it will looked darned sexy ... well if I do it right it will First off: Take some big sheeting. For this I got a 2 sqm sheet from our boys at CarbonMods.co.uk - great service and pricing again ! Then, remove the rear seats and make a template for the offending area from the cardboard box that the sheets came in: Template made, now for cutting.... gulp First little tricky bit done No incidents so far .... Full outline done and first test fit... A bit more faffing around and trying to figure out a way to mark the holes for existing threaded holes to save drilling the car and here is the finished result: Well chuffed Duncan : www.racedynamix.com
small update...
Whiteline Camber Bolts fitted this morning. Pretty easy job but left geometry undisturbed for the mo (as best I could) While I was doing this I dropped the front of the car by 8mm to level it off with the rear. Templates for canards created - not sure whether I am actually going to fit them but we will see I will cut them out this afternoon and see what they look like I have also made the measurements for gurney flap to fit to the rear spoiler and calculations for the drawings made That should be interesting here are the canards cut out of the carbon sheet: Duncan : www.racedynamix.com
i have absolutely no idea but they dont protrude beyond the parameter of the vehicle and I have rounded the corners off so would assume they are ok. Duncan : www.racedynamix.com
- Nomex Balaclava
- Nomex Socks - FIA Roll Cage padding - Aerocatches - looooooads of 80mm ID brake ducting (if anyone needs any please let me know I will have loads spare !!!) - some misc aerotek nuts and bolts that are always handy to have in the tool kit. - some yellow electrical tape for the negative terminal on the battery on their way to me.... - Corbeau Sprint seat from Mr APT - Bride rails from Japan - Roll Cage from Japan Car goes in for the open heart transplant on Tuesday - I cant wait !!!! Thanks to all suppliers for getting everything to me in time and for putting up with endless changes of mind (especially Mike Tuckwood & Jase) Duncan : www.racedynamix.com
oh and picking this up tomorrow
Very nice spec, its gonna be one hell of a motor
That rear wing looks very similar to the one on the latest Spec C Type RA-R......
thanks mate. I am hoping that it will be quick
btw - if anyone wants to watch the final Time Attack at Snetterton in VIP luxury, let me know as I have the VIP suite booked for my home event Duncan : www.racedynamix.com
Who is onlineUsers browsing this forum: No registered users and 17 guests |
