Simple power mods?
Postby WAYNE WRX » Thu Sep 18, 2008 10:12 pm
marky mark wrote:320 PS IIRC, which converts to about 315.616 BHP. Roughly.
Thats very acurate Image
WAYNE WRX
Postby JP » Fri Sep 19, 2008 11:40 am
MM knows his stuff! :)
JP
simple mods
Postby supracat » Tue Dec 16, 2008 7:00 pm
ok. have bitten the bullet and the following mods are being fitted on mon 22nd Dec. - will aim to update everyone with a before and after.
Current car spec is std with exception of H&S centre pipe.
Mods will be;
1. H&S straight through downpipe to replace the two existing cats
2. K&N air filter
3. Resonator mod
4. Ecutek and AF remap
hopefully get close to or near my target of 350bhp/torque. - my mate Dunc at Hypertech will do all the before/afters and fitting.
supracat
Postby Gee Wr1 » Tue Dec 16, 2008 7:33 pm
Where are you getting the intake mod from? take it you mean the snorkus pipe to get rid of the resonantor box in the inner wing?
Saw these before & quite fancied one as the up the induction volume on the standard air box. The were only available in the states when i saw about them.
simple mods
Postby supracat » Tue Dec 16, 2008 8:23 pm
i think so. - just leaving it in the very safe and capable hands of dunc.
supracat
simple mods
Postby supracat » Tue Dec 16, 2008 8:50 pm
sorry, half asleep - yes, Dunc will remove the resonator to open up the airbox a bit more.
supracat
Postby The Swede » Tue Dec 16, 2008 11:17 pm
Spike has some pic somewhere of my cheap power mod when I had my STi...
Enfield Monkey ! Where are ya ?
Re: simple mods
Postby Gee Wr1 » Tue Dec 16, 2008 11:38 pm
supracat wrote:sorry, half asleep - yes, Dunc will remove the resonator to open up the airbox a bit more.
Ah so your going to Hypertech if it's Dunc then, have heard nothing bad said about him only good. Seems a good combo Dunc's spanner work & Andy F's black magic :D Plenty of folk on scottish scoobies had great & happy results using them together.
Would you mind asking him how much he sells the part for please when your in?
mod
Postby supracat » Wed Dec 17, 2008 4:36 am
yep, not a problem, will do mate.
yes, big Dunc looks after all of our cars and did the 2.5 conversion and mods etc on my P1 - wouldnt go anywhere else.
supracat
Postby b12rlw » Thu Feb 26, 2009 10:06 pm
I'm a bit unsure of the truth in the exhaust gas temerature statement. I.e.
"The more energy you can keep in the exhaust gas (in this case heat), the faster that gas goes."
Never heard of such effect in years of pipeline design! Consider the statement! Do you really think that an increase in the pipeline material temperature is going to have a detrimental effect on gas flow rates?
b12rlw
Postby marky mark » Fri Feb 27, 2009 5:59 pm
b12rlw wrote:I'm a bit unsure of the truth in the exhaust gas temerature statement. I.e.
Holy thread revival batman. :lol:
Well i am sure. It's basic physics. For a given gas volume, it's pressure will increase as the temperature increases.
Not sure what pipes you design, but since time imemorial car / bike racing teams have been lagging (a bit pikey but cheap) or coating with ceramics etc. I'm not saying it makes a massive difference but every little helps. This includes F1 teams and i suspect they know a bit more about this kind of stuff than you or I.
b12rlw wrote: Do you really think that an increase in the pipeline material temperature is going to have a detrimental effect on gas flow rates?
Any heat that can be kept out of the pipework means more heat in the exhaust gas. Heat, as i'm sure you know, is nothing more than energy. Particularly in turbo applications, As much energy as possible in the exhaust gas is a good thing for obvious reasons.
Postby dynamix » Fri Feb 27, 2009 7:18 pm
Although you dont want EGT's too hot
Duncan : www.racedynamix.com
email: duncan@racedynamix.com
tel: 07540 185754
dynamix
Postby Foley » Fri Feb 27, 2009 8:14 pm
I had a ceramic coated FMS manifold and decat on the RS, Manifolds looks good when it's cermic coated, I got mine done by zircotec who do exhausts for honda and renault in F1, They also do many rally cars, It aint cheap tho!
This is my first scooby so am still learning :) , I was told if i was getting a remap and decat i would need an uprated fuel pump is this true?
Foley
Postby dynamix » Fri Feb 27, 2009 8:30 pm
probably
tel: 07540 185754
dynamix
Postby Gee Wr1 » Fri Feb 27, 2009 9:09 pm
Foley wrote:I I was told if i was getting a remap and decat i would need an uprated fuel pump is this true?
No uprated pump needed as the wr1 had an uprated pump fitted by Prodrive as part of the package. 255 pump if i mind right.
Postby Foley » Fri Feb 27, 2009 9:21 pm
God so many tuners tell so much s.h.i.t.e sometimes,
Foley
Postby Gee Wr1 » Fri Feb 27, 2009 9:32 pm
n.o. s.w.e.a.r f.i.l.t.e.r o.n h.e.r.e i.t.s o.k y.o.u c.a.n s.a.y SHITE :wink:
Postby Foley » Fri Feb 27, 2009 10:36 pm
Gee Wr1 wrote:n.o. s.w.e.a.r f.i.l.t.e.r o.n h.e.r.e i.t.s o.k y.o.u c.a.n s.a.y SHITE :wink:
cool :D
Foley
Postby WR 1mposter » Sat Feb 28, 2009 1:54 pm
Depends on how much power you require also, above 400 fitting a FPR may be required, above 450 perhaps a even more uprated fuel pump like the bosch, but it is slighty noisier.
Postby Gee Wr1 » Sat Feb 28, 2009 2:56 pm
All he mentioned was a decat & remap which wouldn't need a new pump. Yeah if he was heading for big numbers then he would have to think about changing it along with the other mods required.
Postby Foley » Mon Mar 02, 2009 3:17 pm
Gee Wr1 wrote:All he mentioned was a decat & remap which wouldn't need a new pump. Yeah if he was heading for big numbers then he would have to think about changing it along with the other mods required.
Cool so i don't need an uprated fuel pump, Just going for a pannel filter decat and remap, Will i see 350bhp with these mods? Has the wr1 got two cats? If so do they both cats need took off? Is the decat the same decat as the STI?
Cheers j
Foley
Postby WR 1mposter » Mon Mar 02, 2009 7:35 pm
Cheers j
You'll probably get arounf 335/340, would get over 340 if a induction kit was fitted.
Prodrive downpipe is the only cat on WR1 or a sti with ppp.
Postby Foley » Mon Mar 02, 2009 7:51 pm
Cheers j
Where can i buy prodrive decat, looked on ebay but don't really know
what am looking for,
Cheers j
Foley
Postby rocko » Mon Mar 02, 2009 8:00 pm
Well .. i was running around 340.... mine was 311 bhp standard
when i had Rcm induction kit, ecutek map,
And if your goin for a decat .. id go for a 3" system
But you need to ask your self whats your budget..? cause the list certainly goes on as we all know
rocko
Postby Gee Wr1 » Mon Mar 02, 2009 8:23 pm
Don't think prodrive do a decat its aftermarket manufacturer's your looking for.
Postby WR 1mposter » Mon Mar 02, 2009 8:24 pm
Cheers j
Cheers j
Prodrive don't do a decat, what I meant was the cat on the car is made by Prodrive, so you'll have to buy a aftermarket decat, but do you just buy the decat downpipe or do you get a full 3" stainless system like rcm or aps both similar price, so if you have a budget it will depend on which way forward for you !
I started with 340, but it is never enough you'll always want more :lol:
Previous
