my xmas pressie from the cats has arrived ....A nice Perrin lightweight crank pulley :
Thanks puuuddies The standard crank pulley weighs 2.5kgs This weighs 550 grams so saves 2kgs over standard in rotating mass so should accelerate better. I am not sure whether I will be able to notice it but every little helps I have now changed it having fought to undo the crank bolt .. the fekker so will give it a run out later on. Duncan : www.racedynamix.com
Perrin are getting very good press at the moment with their product range both scoob and evo worlds Crash bang wollop!!
I have just weighed the std pulley and it is 3kgs
So 2.5 kgs saving ... nice Duncan : www.racedynamix.com
Looks understated and being the same size as the original it wont have any underdriven problems. Duncan : www.racedynamix.com
it wont change the power the engine is producing but it will have a small impact on acceleration.
WHY NOT ...................
Just push your foot down quicker Couldnt help but give you that technical answer mate Crash bang wollop!!
How small?!
I havent measured yet Dan but I will tomorrow
I have to say that I am very impressed with the quality, weight and fit of it Duncan : www.racedynamix.com
Thanks looks pretty easy to fit ..apart from the crank pully bolt .. 90lbs ! lol .. knowing my luck ill snap the bitch lol
94lbs/ft is the tightening torque but it is a fek of a lot stiffer than that to undo
I used a long (ie 4ft) trolley jack handle and even then it was stiff !! Duncan : www.racedynamix.com
You should really not admit that fella And get out a bit more
