how to change front sidelight bulb ???
Postby steff109 » Fri Mar 30, 2007 9:18 pm
how on earth are yoiu supposed to change the front side light bulb on the headlight ??
steff109
Postby WR1 Bro » Fri Mar 30, 2007 10:42 pm
Personally I would take it to a garage :shock:
Postby danr55 » Fri Mar 30, 2007 11:09 pm
WR1 Bro wrote:Personally I would take it to a garage :shock:
me too
Postby WR 1mposter » Fri Mar 30, 2007 11:34 pm
1. Take off front grill, there about 5/6 plastic clips, but be careful very fragile and remove grill !
2. There are 5/6 plastic poppers on the bumper , screwdriver under the centre section and prise up and remove, then pull the bumper away slightly from the car !
3. A white clip/bracket attach to the headlight, (again fragile) on with a 10mm bolt remove plus the 2 bolts on the top of the headlight assembly
4. Your headlight is now held on with 2 clips on the innerwing so again gently prise the headlight away from the car, just enough to get you hand in and twist the side light bulb out and replace !
5. Follow in reverse order to put together again !
6. Take it to a dealer and let them do it ! its a 10 minutes job for someone who knows what ther doing and a couple of hours if they dont !
Plus you may break the grill clips and the white headlight bracket !
Hope this helps,done 1 of mine last week :roll: easy when you know how really :wink:
Postby WR1 Bro » Fri Mar 30, 2007 11:36 pm
WR 1mpostor (aka number 1 moderator) wrote:1. Take off front grill, there about 5/6 plastic clips, but be careful very fragile and remove grill !
Great explanation mate...
Like I said, take it to a dealer!
Postby WR 1mposter » Fri Mar 30, 2007 11:49 pm
Thanks mate a lot of thought went into that :wink:
Postby WR1 Bro » Fri Mar 30, 2007 11:50 pm
No doubt Marky Mark will come along and give us GPS co-ordinates for the bolts if the car is parked in Rusholme.
Postby steff109 » Sat Mar 31, 2007 6:54 am
thank you very much for that much appreciated gonna give it a go on monday at work wish me luck i thought easy service items like bulbs were supposed to be made so any joe blogs could do it they may as well have put the fixing screw for the headlight inside the fuel tank and made it really easy :lol:
steff109
Postby Mac-1 » Sat Mar 31, 2007 11:19 am
That
Mac-1
Postby WR 1mposter » Sat Mar 31, 2007 3:55 pm
That
Postby marky mark » Sat Mar 31, 2007 4:41 pm
How many WR1 (or ex WR1) owners does it take to change a light bulb?
3
Pasty to spanner, Bro and Dan to admire each others dresses and ask if there "bums look big in this"
:rofl:
Postby WR 1mposter » Sat Mar 31, 2007 10:55 pm
marky mark wrote:How many WR1 (or ex WR1) owners does it take to change a light bulb?
3
:rofl:
:stfu: :rules: off topic :finger:
Users browsing this forum: No registered users and 38 guests
