Bonnet Dampers
Re: Bonnet Dampers
Postby simon.r » Fri Dec 21, 2012 8:18 pm
Oooo how much are these ? Easy to fit ?
How do you go abouts closing the bonnet now - you dont have to push it down on the bonnet itself?
That is one nice looking engine bay - Loving that strut brace - got to get myself one of those.
Simon
simon.r
Re: Bonnet Dampers
Postby goonas » Fri Dec 21, 2012 8:57 pm
simon.r wrote:Oooo how much are these ? Easy to fit ?
Simon
He's mentioned earlier:
I can arrange a group buy for 10 sets of bonnet dampers @ £42.95 plus postage £6.00. Total price £48.95
For those who are still interested please email your details.
Payment will be via paypal using my email address or personal cheque. I will forward my address details for cheque payments.
Once i have payment for the 10 sets i will forward all details and payment to supplier.
Thanks
Gary
Lunacy is a right foot away.
goonas
Re: Bonnet Dampers
Postby Gary75 » Sat Dec 22, 2012 12:33 pm
Remove the top bonnet hinge securing bolt then place the upper bracket / ball joint, then secure with same bolt, dont overtighten. The lower section ,remove the middle wing bolt, then replace with the lower damper ball joint. Connect damper to upper and lower joint, insert the wire clips to stop the dampers popping off the upper and lower ball joints, job done :thumb:
Open the bonnet, lift, there maybe slight resistance to half way open, the dampers will then take over. Closing the bonnet, there will be slight resistance as you lower to half way, then close as normal. Please note, resistance is only slight. The bonnets weight and gravity does the rest. No pushing or pulling required :shock: Hope this helps....
Re: Bonnet Dampers
Postby simon.r » Sun Dec 23, 2012 12:49 pm
Yeah put name down on the list and we'll give them a go why not.
On a seperate matter - with regards to the strut brace did you not much difference after fitting? It does finish it off nicely.
Cheers Simon
simon.r
Re: Bonnet Dampers
Postby Gary75 » Sun Dec 23, 2012 2:33 pm
1 x set Venkman
1 x set SteveS
1 x set davetwr1
1 x set Gonnas
1 x set simon.r
Come on 5 sets more then i can order :thumb:
Re: Bonnet Dampers
Postby Gary75 » Sun Dec 23, 2012 2:38 pm
simon.r wrote: On a seperate matter - with regards to the strut brace did you not much difference after fitting? It does finish it off nicely.
Cheers Simon
I have both front and rear strut braces fitted, does stiffen the car alot, also exe-tc suspension fitted. I did have some high speed handling issues but this was due to the exe-tc suspension sitting on the front bump stops, hence no damping :shock: the tyres was taking all the load, so my arse was constantly gripping the seat when cornering :x all sorted now.
Re: Bonnet Dampers
Postby S4lford » Sun Dec 23, 2012 7:19 pm
count me in for a set
S4lford
Re: Bonnet Dampers
Postby Gary75 » Sun Dec 23, 2012 7:42 pm
1 x set Venkman
1 x set SteveS
1 x set davetwr1
1 x set Gonnas
1 x set simon.r
1 x set S41ford
Re: Bonnet Dampers
Postby Gary75 » Thu Dec 27, 2012 11:07 pm
Christmas money to spend :?: then treat the 1 to some bonnet dampers :D only need another four sets then I can order...
Re: Bonnet Dampers
Postby simon.r » Mon Jan 21, 2013 2:08 pm
Any news?
Do we have to have 10? :D
simon.r
Re: Bonnet Dampers
Postby Gary75 » Mon Jan 21, 2013 2:57 pm
simon.r wrote:Any news?
No we only have 6
Re: Bonnet Dampers
Postby Dayo » Sun May 31, 2015 11:01 am
Are these carbon dampers? Where can i get them from and what price?
Finally Got My Hands on a WR1 #039. Loving it ;)
Dayo
Re: Bonnet Dampers
Postby Gary75 » Wed Jun 10, 2015 8:56 pm
Dayo wrote:Are these carbon dampers? Where can i get them from and what price?
Hi Dayo, these are standard dampers but contact the company direct. Visaul performance based in Swindon, they do dial kits, lights etc
Re: Bonnet Dampers
Postby Dayo » Wed Jun 10, 2015 9:09 pm
Iv got some carbon ones now mate
Dayo
Previous
Users browsing this forum: No registered users and 51 guests
