Changing cat pipe - will it have much effect on loudness?
Posted: Tue Apr 26, 2011 1:22 pm
I fitted an Afterburner backbox a while back and then changed the centre section for an Afterburner one. Where the centre section meets the cat pipe there is a slight blow as it doesn't line up 100% straight, so there isn't a tight seal.
The logical solution to this, I think, is to change the cat pipe for an Afterburner version. However, the car is pretty loud as it is and I'm not sure I want to annoy the neighbours any further
Has anyone done something similar, or got any better ideas?
Much appreciated
Much appreciated
