Rota Wheels
Rota Wheels
Postby brenmyster » Tue Sep 21, 2010 2:48 pm
Hello Guys
Looking at a set of Rota wheels with a custom paint job as a cheap alternative to change the look of my 1.
Any info on these wheels would be great?
Thanks
Simon :D
Regards and be lucky !
Simon
#226
brenmyster
Postby chiroman » Tue Sep 21, 2010 5:57 pm
Check the weight of the Rotas against the PFF-7's.
chiroman
Postby brenmyster » Tue Sep 21, 2010 6:59 pm
They are lighter about 7kgs each. As they are cast and not forged.
What difference will this make. Do you know ?
Simon
#226
brenmyster
Postby CAVEMAN » Wed Sep 22, 2010 6:51 am
lighter wheels reduce whats known as the un-sprung mass. This means that the suspension works more effeciently as it doesn't have have a great whacking weight on the end of it.
The lighter the whole suspension assembly the better, as it reduces inertia...so the suspension can change direction a lot quicker and be more responsive overall.
However as the whole set up here is on a road car, and you ain't changing the suspension set up then I doubt you will notice much difference, but lighter by 7Kg over the PFF's is quite a lot!
I don't agree with a cast wheel being lighter than a forged wheel buddy. Casting is basciually pouring the molten material into a cast..and as the material isn't under any stress then they usually need more material per given wheel design to acheive the same strength. Whereas forging takes a blank bit of material and deforms it under pressure. This plastic deformation increases the yeild strength so doesn't require as much raw material, so therefore is lighter.
There is also the heat treatment aspect of it too, and the fact that forged items will keep thier shine a lot longer than cast items too, as cast items are still very porous.
Postby brenmyster » Wed Sep 22, 2010 8:58 am
Hey thanks for the good info ......my bad on the weight. 7kgs in total per wheel which I think is a tad lighter than the prodrive originals.
Heard mixed reports on Rota wheels themselves so was a little unsure.However cant grumble at the price.
:D
Simon
#226
brenmyster
Postby chiroman » Thu Sep 23, 2010 6:32 pm
Typical flow forming as in Prodrive Flow Form -7 spoke PFF-7:
http://www.youtube.com/watch?v=ukBAD8IDxds
chiroman
Postby hightower » Fri Sep 24, 2010 9:31 am
i had ultraleggeras and they were light as fook.
gone...Impreza RB320 No 112
gone...Impreza WR1 No 84
gone...Civic Type R EP3
gone...Seat Leon Cupra 225
gone...(shed with weels)
hightower
