Hi all thinking of replacing Fuel pump and spark plugs ..
What would you choose .. and make ?
And is it an easy job... would i need the maping tweeked again ..?
Thanks
Fuel Pump And Spark Plugs ..Hi all thinking of replacing Fuel pump and spark plugs ..
What would you choose .. and make ? And is it an easy job... would i need the maping tweeked again ..? Thanks
Yep, the fuel pump you have already is man enough for 400 BHP so if you don't plan on going further than that leave it. You won't get any more power by changing the pump anyway.
NGK PFR7B's are the plugs you want (standard are 6's) if you want to change them. These work fine from standard spec all the way up to 400+. www.pentlandcomponents.co.uk Are about the cheapest you will get unless you want to risk Ebay. Ask for Rich Small and tell him i sent you. If JP is Roland Rat, them I am Errol the Hamster... His number 1 fan.
