FAO Mark
![Post Post](./styles/AeroBlue/imageset/icon_post_target.gif)
Hello mate,
Where can I buy some stainless steel wire for wrapping my downpipe? What diameter do I need?
Anders
Anders
Spike "THE LEGEND" Mike XXX wrote:Demon tweeks will do you stainless steel ties
marky mark wrote:You get the best job by using ties and lockwire. Ties on there own you cannot get them tight enough and eventually the wrap comes loose so use a few ties (they are expensive) to hold it in place and then lockwire it.
You won't get a good job doing the wiring with pliers either, you need some proper lockwiring pliers. When you are ready give me a shout and i will lend you mine.
Demon tweeks are fecking expensive. speak to the guys at
http://www.proven-products.co.uk/ , they will supply you with cooltek lagging, stainless ties, and lockwire.
In fact the link to cooltek is on there.
Anders_WR1 wrote:Just ordered a 2" x 50' roll of DEI wrap. Not too cheap this stuff...£67 delivered
WR 1mpostor (aka number 1 moderator) wrote:Anders_WR1 wrote:Just ordered a 2" x 50' roll of DEI wrap. Not too cheap this stuff...£67 delivered
Got a roll of wrap left over from last time.
Anders thought you had my o.e headers ported, why wrap them when they had heatshields ?
WR1 Bro wrote:I didn't realise that when you heat wrap that you had to lock wire it.... Thinking about it, I don't know how I thought it stayed in place! Maybe cable ties!!!! This is another great example to me how interesting this site can be when people post threads about what they are doing and then pics of what they have done.
Good job Anders. I've learnt something from something so simple.
I thought heat wrap was like a metal gauze (sp?) and thus thought you bent it around the pipe and hence it would stay in place. What a pleb.
Anders_WR1 wrote:Cheers for the feedback lads. I enjoy doing this stuff, where I can.
I had the MD321H, Hayward & scott and clutch fitted today at API, but I won't be getting it mapped for another week or so. API left the wastegate flapper disconnected, until I get is mapped to stop the turbo spooling to dangerous levels.
Even with the wastegate fully open, I'm convinced the turbo response is better than the VF35. On the old turbo, if I had my foot off the loud pedal and the boost gauge needle was showing vacum (right down the bottom on the gauge), it would always take a second or so to reach 0 on the gauge when I pressed the loud pedal again. With the new turbo, it happens a split second after touching the accelerator.
I'm looking forward to mapping and to see what happens powerwise, given that I'm still running ported OEM headers. I thought I'd give them a go before spending £500 on tubular headers.
Anders
littl`un wrote:does that mean there`s a vf35 going?
also, where did you get the turbo blanket from?
Tiny
dynamix wrote:Anders_WR1 wrote:Cheers for the feedback lads. I enjoy doing this stuff, where I can.
Anders
Sounds about right from what I have heard of the H - instant spool up. It will transform the 1 into a very driveable and rapid car.
Stick with the OEM headers
WR1 Bro wrote:Looking forward to seeing you car at the RR.
littl`un wrote:shame the turbo`s already gone but cheers for the link to the turbo blankets
