Anyone know the best place to pass a power lead from the battery through the bulkhead without drilling holes.
Also which rating of inline fuse to use with a 2x100watt amp?
Amp power leadAnyone know the best place to pass a power lead from the battery through the bulkhead without drilling holes.
I`ve just done an install on my motor & found the easiest place to get the powerlead through the bulkhead is through the a/c grommet! It`s a pretty large rubber grommet with 2 pipes going through the middle & all I did was to pierce it (gently!!) with a sharp screwdriver & feed the lead through.
I removed the glove box too as it`s far easier to locate the lead from the foot well side & u also need to remove the sill trim to feed the cable under the carpet! All fairy easy though & goes back together easy enough !!!
