Kncoking in the bootI have a rather pathetic problem and would appreciate some advice. I have a knocking sound from the boot. No its not some victim of the Goodfellas - but I suspect the cardboard wheel cover panel flapping up and down. Anyone else had this problem and found an easy fix?
i'd say it was shocks too - sorry.
To check - open boot and sit up and down on the boot lip - you will hear the knocking there. Duncan : www.racedynamix.com
yer i am getting the same sound thats why i asked m/d when it went in last week they said they couldnt here it,
i was thinking the same maybe the spare wheel cover havent got round to check it yet will do tho let me know what yours is if you find out Regs
Deffo your shocks Geoff....dealer in baldock will do anything to get out of doing them
You may even get them to order the right parts 2nd or 3rd time Make sure you get a pair replaced aswell..not singularly. Crash bang wollop!!
If you have not had the shocks done under warranty in the 3 years,
I don't know where you stand ! I suppose there is a case in being there is a common fault with the sti8, a factory recall should have been done, or in the very least them stating we know there's a problem, if they go outside of warranty we will honour it .....but we know that ain't going to happen. Got my shocks done over the phone, they never even took it for a test drive. 2007 BMW M5
got my rears done at Welchs in Cambridge - did the pair of them.... it is still a problem with them
Not my shocks, they were done last month, I'll try some rubber washers round the spare wheel cover. I've thought of removing the spare wheel too to lighten the load and get some of that spray/tyre repairer stuff I used when I had TVRs.
Check the jack located behind the flap in the N/S of the boot these can work loose over time and rattle.
Ant,
both my cars are needing the shocks done argh 600 quid per car.
get some coilovers on there - may as well now
Hi mate are you sure as I have never heard a peep out of the rear shocks when I had it, if I had it would have been straight in for free replacements before the warrenty run out !!! Ant,
This should have been a recall There have been so many 1's and sti8's that been done.All should have been done under a recall. 2007 BMW M5
Is there any way you can tell if it's been done ?
I've asked Quinby's to confirm it has been done on mine, but would like to check myself if possible. When I'm not driving I'm Skiing !
Phone IM motors, the subaru uk importers, they are very helpful 2007 BMW M5
Dealer replaced my rear shocks for free..as a good will gesture..and warranty had run out 3 months prior..
________ Dutch recipes Last edited by stanley on Sat Feb 19, 2011 5:06 am, edited 1 time in total.
Yeh mate the Black sti is much worse than the WR1 the wr1 only has a very very slight knock on the passenger rear, safe to say they will need doin at some point but a long way off at the moment ! That said, I should really check the wheel well for anything loose Was meaning to ask you how I get in there actually with all the sound equipment in there lol Previously: Everything With 4 Wheels over 300bhp
Check your drop links aswell, they do come loose 2007 BMW M5
Cheers m8 will do
Hi,
just had the rears replaced on my WR1 under warranty too - has made a big difference to the drivability already, and apparently my rears weren't 'too bad' either. Is this a common problem?? Should the replacements last any longer than the originals or will i have the same problem again? - my WR1 has only done 12k miles now and i dont want to keep getting these replaced all the time! Cheers.
Big fault on STi'8 some have had a couple of sets. Perhaps the best option would be coilovers next time round if the warrenty is out, possibly cheaper aswell and defo better handling woth the right geometry set-up 2007 BMW M5
Had our shocks replaced as well, still get a noise like a click when on and off the throttle, sounds like diff to me, anyone got the same?
Will spanner check rear end tomorrow Think I need to check out the 08, sorry guys but this car aint a patch on the wife's 104k P1
Paul N i get that noise on a 05 Jdm sti and same some times when changing gear there not a sound when acelarating hard but getting the car's suspension checked over next weekend if it is the shockers there of for a set of tein basic coilovers
05 REG JDM Sti zl
Mine's had two rears and a front replaced.
All the same problem. Ex 05 Sti PPP Type UK
300 BHP, 298 FtLb Now Vw Scirocco GT 140 BHP
Thanks Dipsey, can you let me know how you get on?
Edit to add no noise under power, just when changing gear, backing off, coming onto power if that makes sense? Much apreciated
Had the rears replaced on ours, made no difference, that's why Im thinking diff, could be the strut top mounts?
Thanks for that, be interested to see what they say next weekend
