Defi's low boost???Just fitted a set of defi's took the car for a spin to check everything is fitted ok, and the boost seems a bit low it peeked at 1.1 bar what could be causing this?? does it only reach 1.3 when flat out in say 5th or should i be getting 1.3 in lower gears too
Try disconnecting the battery for a few minutes to reset the ecu.
Then give it a load of stick to get it to learn in "fast" mode Crash bang wollop!!
just gave it another run somethings up, ill try disconnecting the battery and if that doesn't work maybe try subaru and get the ecu reset!!
Who is onlineUsers browsing this forum: No registered users and 9 guests |
