by Anders_WR1 » Mon Jul 09, 2007 5:05 pm
flett_66 wrote:Just purchased a WR1 with 10K on the clock with 1 previous owner, great car. Only concern is i can only get 95 ron fuel where i am. Been using miller oils octane booster. is this sufficient to prevent damaging the engine etc?
cheers
I'm sure I read that every car sold in the UK has to run on standard 95 fuel. You sholud be ok if your using booster - the ECU should adjust the ignition timing to compensate for a slightly lower octane, although this will mean you will loose some power.
Have you tried Nitrous Formular octane booster? I've never used it, but it's supposed to be good stuff and cheaper than Millers.
Anders
