Squeeling Brakes
Squeeling Brakes
Postby presa900 » Wed Jun 06, 2007 8:45 pm
Spent two hours tonight removing all four sets of pads to check for trapped debris.......to find nothing :evil:
I have been experiencing substantial brake squeel recently under light and medium braking once the brakes are warmed, and even a low level worn pad grinding sound at times. :?
The car has only done 10K miles, the rear brembos have Ferodo DS2500 pads with plenty of wear left, and the 6 Pot AP's on the front have plenty of wear left on them also. Couldn't find anything trapped anywhere :roll:
Gave everything a good clean, will have to see if its cured in the am, but expect not.
Anyone got any suggestions or ideas :?
presa900
Postby Robocop » Wed Jun 06, 2007 8:58 pm
Have you put Copperslip (or similar) on the rear of the pads as this should do the trick?
Robocop
Postby pete_griff » Thu Jun 07, 2007 7:38 am
have you put copper grease (copaslip) on the backs of the pads and on the areas of the disc where it mounts on to the hub. I know this sounds silly and you'd think it wouldn't help to stop any squealing, but try it - you might be surprised
(fairly obvious point - be very careful not to get any grease on the braking surfaces of the pads or discs, and if you do clean it off asap with thinner, white spirit or something similar)
also next time you have the pads off, try roughing up their braking surface with some wet/dry paper
hope this helps
Griff
pete_griff
Postby marky mark » Thu Jun 07, 2007 7:40 am
It's not silly at all, Copaslip is amazing stuff!
Postby pete_griff » Thu Jun 07, 2007 7:45 am
haha :) - yes it is, it also smells amazing - you used to be able to get a big pot of the stuff from halfords-their own stuff, its amazing! :wink:
Griff
pete_griff
Postby presa900 » Thu Jun 07, 2007 10:10 am
Still squeeling like a pig this morning..... :evil:
Cheers for the info guys, can't get my head round putting it on the rear of the pads, but hey I'm game to try anything that might sort it. :thumb:
Gonna try roughing the pad slightly also, they did seem to have a polished feel :?
On another note, I was surprised that the pins on the AP's did not have a security pin through them like the brembos to stop them from dropping out on their own :shock: Will be regularly checking them from now on :wink:
presa900
Postby Robocop » Thu Jun 07, 2007 11:53 am
Brake squeal generally is dust oscillating/vibrating at a certain pitch and giving you the awful noise akin to nails on a blackboard.
Coppaslip (spelt it right this time :) ) effectively helps to alleviate this problem. I
Robocop
Postby marky mark » Thu Jun 07, 2007 11:59 am
you are right, it works, but as for a technical explanation i don't have a clue.
I feel its one for (in no particular order) DanR55 or WR1 Bro. If Spike "THE LEGEND" Mike XXX comments take it with a pinch of salt though as he spouts a right load of old clobber.
Postby marky mark » Thu Jun 07, 2007 12:01 pm
Robocop wrote:
Coppaslip (spelt it right this time) :
No you didn't Kev, Its copaslip :lol:
Or Coppereeze is the trade name of one of the manufacturers.
Postby Robocop » Thu Jun 07, 2007 12:59 pm
Bugger. I'll get it right one day eh. :D
Robocop
Postby WR 1mposter » Thu Jun 07, 2007 11:06 pm
Yes, when I checked ours they were out :shock:
