I had the car serviced last week and I noticed the oil pressure is lower than normal. The oil pressure usually sits around 3 BAR on idle, when the oil temp is about 95 degrees. Now it's closer to 2 BAR.
When the car's cold and I start up the pressure hits 6 BAR compared to the usual 7 BAR.
I'm going to change the oil to play safe, in case the oils fooked. Any tips for changing oil? I heard your supposed to crank the engine over with the crank sensor disconnected so the engine can build pressure without starting?
Anders
