Sticking Revs
Posted: Tue May 15, 2007 10:43 pm
Scenario. In traffic in 1st gear coming to a stop foot off throttle, clutch in and stop, the revs then jump up 3/400 and hold for 1/2 sec at say 1500rpm then drop to tick over
Anders_WR1 wrote:Is your air con switched off? Does that happen every time you stop?
WR 1mpostor (aka number 1 moderator) wrote:Anders_WR1 wrote:Is your air con switched off? Does that happen every time you stop?
Air con switched off !
Explain why the air con would alter the revs by 3/400 ?
Spike "THE LEGEND" Mike XXX wrote:WR 1mpostor (aka number 1 moderator) wrote:Anders_WR1 wrote:Is your air con switched off? Does that happen every time you stop?
Sounds to me like the "flux capacitor" is on teh way out mate...best go to see "the doc"
danr55 wrote:Spike "THE LEGEND" Mike XXX wrote:WR 1mpostor (aka number 1 moderator) wrote:Anders_WR1 wrote:Is your air con switched off? Does that happen every time you stop?
sounds more like the extra load sprocket shaft to me mate
Spike "THE LEGEND" Mike XXX wrote:danr55 wrote:Spike "THE LEGEND" Mike XXX wrote:WR 1mpostor (aka number 1 moderator) wrote:Anders_WR1 wrote:Is your air con switched off? Does that happen every time you stop?
possibly the wogglerog neutraleeder....
danr55 wrote:Spike "THE LEGEND" Mike XXX wrote:danr55 wrote:Spike "THE LEGEND" Mike XXX wrote:WR 1mpostor (aka number 1 moderator) wrote:Anders_WR1 wrote:Is your air con switched off? Does that happen every time you stop?
if it's disconnected itself from the wizbang accelerator that could be the issue...
WR 1mpostor (aka number 1 moderator) wrote:Car is driving absolute pants, revs sticking, missing, farting, knocking..
you name it its doing it
WR 1mpostor (aka number 1 moderator) wrote:Cant blame them just think it needs a bit of tlc and new plugs
WR 1mpostor (aka number 1 moderator) wrote:Think I've found the problem
