Gearbox noise
Gearbox noise
Postby Iain » Fri Nov 12, 2004 1:26 pm
The gearbox on my WR1 makes a strange noise when you decelerate using engine braking. This is particularily apparent when in lower gears, at higer revs and you just take your foot off the accelerator. Unless you hear it, the noise it hard to describe. It's a rough sounding meallic noise that's audible over the general transmission noise. When starting from cold, the noise is not apparent. But after a few hundred yards and a warmer car, the noise starts. It gets worse for a while and then levels out. Subaru reckon it's something to do with a bit of vibration in from the gearing and is normal for this type of gearbox. Is anyone else experiencing this?
Iain
Postby jaycee » Fri Nov 12, 2004 1:30 pm
Hmmm. I'd be getting a 2nd opinion from another dealer.
That doesn't sound so good.
jaycee
Postby Cold Turkey » Fri Nov 12, 2004 1:31 pm
nope. haven't heard that one ... I do get a quiet whining noise when the engine is cold .... I used to think there was a Police Car or Ambulance approaching from a long way off with its sirens going :?
Cold Turkey
Postby D3ave » Fri Nov 12, 2004 2:03 pm
Not on mine, it sounds the same as the others that I have had,
Would definatley seek a second opinion.
Dave
D3ave
Postby Brian » Fri Nov 12, 2004 2:17 pm
No noise like that over here either.
Keep us informed mate.
Brian
Postby Sumo » Fri Nov 12, 2004 3:10 pm
Nope no noise like that here either, as I'm a bit of a boring barsteward without multi-million pound ICE I often drive with no stereo on, and I've never heard any orrid noises at all, only the 4wd whine, but I quite like that noise, its kinda comforting.
So I would say you have a problem that needs sorting. Its time to take any mods off and get a second opinion as above....... sumo :lol: :wink:
Sumo
Postby chris » Fri Nov 12, 2004 5:05 pm
I'm going with the flow here as well in that mine's fine and you've guessed it, get a second opinion on it! :roll:
chris
Postby Iain » Fri Nov 12, 2004 8:52 pm
Yeah the second opinon is definitely on the cards. But my dealer is fine, it was a chap from Subaru UK who span me the yarn. I'll let you know how I get on. Apart from that the car is great mechanically and performs as it should :wink: . Oh if you haven't done so already, check the mesh grills on the front of your cars. They are held on by stick on clips and the clips tend to fall off. For some reason the replacements seem to be taking an age to arrive from Prodrive
Iain
Postby chris » Fri Nov 12, 2004 9:17 pm
I'd guess they haven't made enough of them to keep up with the demand of the replacements... :wink:
chris
Postby Iain » Sat Nov 13, 2004 5:44 pm
:D
I reckon you could find out where the WR1 owners live just by following the trail of clips on the road :lol:
Iain
Postby Mike Wood » Sat Nov 13, 2004 9:49 pm
Don't know what the problem is as there are more than enough clips in stock at Subaru UK.
Mike
Mike Wood
Re: Gearbox noise
Postby rizzy » Sat Nov 13, 2004 11:57 pm
Iain wrote:The gearbox on my WR1 makes a strange noise when you decelerate using engine braking. This is particularily apparent when in lower gears, at higer revs and you just take your foot off the accelerator. Unless you hear it, the noise it hard to describe. It's a rough sounding meallic noise that's audible over the general transmission noise. When starting from cold, the noise is not apparent. But after a few hundred yards and a warmer car, the noise starts. It gets worse for a while and then levels out. Subaru reckon it's something to do with a bit of vibration in from the gearing and is normal for this type of gearbox. Is anyone else experiencing this?
got the same problom with our wr1.
rizzy
Postby Chris B » Sun Nov 14, 2004 4:40 pm
I've not noticed a noise either so I'd definately get that second opinion.
I thought I was the only one to have problems with those bl@@dy clips. My dealer told me that I must have hit a bird to make the grill loose but it has been like that from day one. We had a closer look at it and found that the clips wern't in the right position to grip the mesh. They seem to be positioned for possibly a smaller gauge mesh. I had an oppurtunity to check the grill on Brian's WR1 and his seem to be a more secure fitting.
Chris B
Postby Ant » Sun Nov 14, 2004 11:05 pm
Yep my grill brackets have also fell off pointed it out at first service where they repositioned the remaining 2 brackets as they where both on the same side, booked in for 5000 service a week friday so hopefully they have the parts in as its only 5 months since the 1st service and had heard nothing until I said about it when I booked it in and they said they thought the had something in for me!!!!!
Ant,
Had an my99 uk classic,
Then got P1 (0329),
Then got a my00 UK Classic,
Ant
Postby Millie » Sun Nov 14, 2004 11:53 pm
No noise from mine.
Millie
Postby rizzy » Mon Nov 15, 2004 2:22 am
had the wr1 for 3 days and some drunken idiot has written my rear end off,the car looks fine from outside apart from the bumper and exhuast,but the under the boot there is a big dent and crack like the metal has been compressed and the carpet wont go down properly is it a rite off?
rizzy
Postby Iain » Mon Nov 15, 2004 11:43 am
Mike Wood wrote:Don't know what the problem is as there are more than enough clips in stock at Subaru UK.
Mike
Thanks Mike for the in-stock tip. When are you next blasting around Castle Combe?
Iain
Postby Iain » Mon Nov 15, 2004 11:46 am
rizzy wrote:had the wr1 for 3 days and some drunken idiot has written my rear end off,the car looks fine from outside apart from the bumper and exhuast,but the under the boot there is a big dent and crack like the metal has been compressed and the carpet wont go down properly is it a rite off?
:shock:
You must be gutted :(
Iain
Postby D3ave » Mon Nov 15, 2004 12:07 pm
How about posting some photos of the damage,
D3ave
D3ave
Postby Iain » Tue Nov 16, 2004 4:07 pm
Just rung my dealer and the clips are there for my grill, about time too. :)
Iain
Postby mr optimax » Tue Nov 16, 2004 10:51 pm
had my car pranged by some idiot going to fast :evil: :evil: hit n/s/r corner :evil: :( all looks like new now :) car was 6 weeks old.
mr optimax
Users browsing this forum: No registered users and 26 guests
