Mudflap heightQuite a few of you have put mudflaps on their cars.
I just got my Prodrive flaps and want to put them on this weekend. What 'height' would you advice to put them ? There seems to be a lower and a higher position. I assume the higher position is safer with the lowered Prodrive suspension but are they still effective then ? Or should they really hang in their lowest position to work well ? Any do's and don't's from people who did the work themselves ? Tak ! Homie the Swede
If you mount them through the upper holes (low setting) they are nearly touching the floor on the front. I mounted the fronts on the high setting (lower holes) and rears on the low setting (upper holes) as rear has more ground clearence.
Ant,
Thanks for the advice ! They can't be too low as they'll just collect a truckload snow. Will probably hang them high at the rear too. There's nobody living here to drive behind me and the only thing it will do is stop the powder snow of covering my numberplate Mind you, it would be nice if they stopped the rear always being dirty after 3 miles.
Even on the low setting the rears still have loads of clearence, but fronts on low setting is a big no no.
Ant,
ours are mounted on the lower settings
front and back ...and they've not scraped or touch the road even on speedhumps 2007 BMW M5
And that's in the Cornwall forest ! I'll need to check that. Any don't's when fitting them ?
pretty strait forward but don't tighten too much, leave them loose enough to adjust,until your happy there level 2007 BMW M5
same here ! gotta be better than me looking at it thinking how hard can this be, and swearing a lot, and taking a whole afternoon to do it !!
Dan... read again... I said... "it looks like a job even a donkey like me could do" Do you see the name 'Dan' anywhere ? You guys really have to stop taking Oestrogen tablets !
Randi, Swede, turnip, professor, homie, donkey... I'm really a multi-character individual here
Hey Mod's, can we change that Torrekens back into The Swede. I can do with some stability in my life.
Who is onlineUsers browsing this forum: No registered users and 21 guests |
