Rear Brake pipes needing replaced
Postby seanyb » Tue Nov 29, 2016 7:33 pm
Hi guys, got a pre mot check done on the car and just below the offside rear floor there is a break pipe connector block its where the centre pipe meets the rears all four pipes at the block are corroded, has anyone replaced the rears and if so is it a big job not sure but looks like it runs over the fuel tank (hope not)
seanyb
Re: Rear Brake pipes needing replaced
Postby asperformance » Wed Nov 30, 2016 8:34 am
they do run over the tank as std and therefore if you wish to remain as OE then the tank will need to be dropped tom access
most commonly simply re-route them as its more cost effective
Postby seanyb » Thu Dec 01, 2016 9:41 am
Ok, thanks for that, whats invloved in getting the tank out? and what other route could I take with the pipes?
seanyb
Users browsing this forum: No registered users and 14 guests
